Receive And Send For Afx
#1 Zahi Renno
Zahi Renno
  • 7 posts
    fx-95 :(
    Algebra FX2.0 plus
Posted 27 July 2010 - 06:14 PM
Hello,
I want to make a data acquisition system for the AFX 2.0 and store my data in the matrix. I wasn't able to do so using C so back to Basic.
I'm going to need to understand the working of Receive() and Send() commands.
I was able to get the Send() function working so I thought I'd share my findings with you:
http://trennonix.wor...or-good-ol-afx/
If anyone knows how does the Receive() command work he could probably save me a day's work, so any help on this manner is more than welcomed.
#2 veb
veb
  • 43 posts
Posted 28 July 2010 - 10:09 AM
I thinh you can only doing that in C.
You can send and receive in C on the afx,
and you can write numbers in the matrix.
There is no exact librairy to write into matrix in C, but you can open a matrix and write bytes into the matrix files.
With the programm 'touche', you can see how a matrix programm is done
You just have to understand were is the number of colums and lines, in which order are the numbers, what change between a martix with complex or without...
#3 ECE
ECE
  • 152 posts
  • Gender:Not Telling
    ClassPad300 Plus o.s3.06.1000
    fx-CG20 o.s1.04
    fx9860GII SD o.s2.00
    fx9860G Slim o.s1.10
    fx9860GSD o.s2.01 (GII hacked)
    Algebra FX2.0 Plus
    CFX9850GBplus
    fx5800p
    fx3650p
    fx570ES Plus
    EA-200 Casio Data Analyzer
Posted 30 July 2010 - 04:05 PM
hi,
long a go i build a data logger for the CFX 9850GB+ based on an article published in circuit cellar magazine, and it's working fine.
you may find it useful.http://www.circuitcellar.com/library/print/1098/britti99/
regards.
