Help With Classpad Sdk...
#1 Premonition
Premonition
  • 4 posts
    ClassPad 330
Posted 06 February 2011 - 02:56 AM
First off, I'm new here so sorry if I put this in the wrong place.
I'm trying to program an add-in for my ClassPad 330 so I downloaded the SDK. However, when I try to change my compiler set there was only the Default compiler and no CPSDK compilers. Now I can't compile my programs into .cpa files. What should I do?
#2 MicroPro
MicroPro
  • Deputy
  • 640 posts
    Casio ClassPad 300
Posted 06 February 2011 - 09:51 AM
Hi. Since cpsdk forums are no longer on the web, this is the correct place to post your questions. :)
Try uninstalling both Dev-Cpp and the SDK and then reinstall the SDK. This must fix it.
#3 Premonition
Premonition
  • 4 posts
    ClassPad 330
Posted 06 February 2011 - 10:40 AM
I tried uninstalling and reinstalling the SDK and Dev-Cpp but it still only comes up with the Default Compiler. Some sources tell me I'm meant do install something else as well as the compiler isn't included in the SDK. Could someone give me a link?
EDIT: It seems I overlooked a part of the programming tutorial where it says I need a Hitachi SH Compiler to make add-ins. I looked around Google but I still can't find it. Could someone give me a link to that?
Edited by Premonition, 06 February 2011 - 10:48 AM.
#4 MicroPro
MicroPro
  • Deputy
  • 640 posts
    Casio ClassPad 300
Posted 06 February 2011 - 07:29 PM
The cpsdk itself contains all the things you need.
But the sdk installer needs to download and install shc_tools.zip from the web.
When installing, do you get any error message about failed internet connections, for example "shc_tools.zip download failed"?
Try connecting to internet and running the installer.
EDIT: Normally shc_tools.zip was on the cpsdk website, but that website is closed so i think installer can't find shc_tools.zip and terminates. See if this is the case.
Edited by MicroPro, 06 February 2011 - 07:35 PM.
#5 Premonition
Premonition
  • 4 posts
    ClassPad 330
Posted 07 February 2011 - 11:41 AM
I got it to work! I found out I was opening the Dev-C++ IDE by itself and not the IDE with the SDK tools. I feel like such an idiot! Thanks!
Edited by Premonition, 07 February 2011 - 11:42 AM.
