So, i'm new to having a graphical calculator and picked this one, but now i'm trying to transfer some Add-in applications, and following the guide works for most of it.
I've installed the FA-124 programme, but when i try to import files it only allows me to choose one file type ( MCS File (*.g1m/*.g2m)), which isn't the file type the add in applications are saved as.
So, what i'm asking is does anybody know how i get it to recognise more than 1 file type?
Please Help!
Cilfaen
, Mar 07 2011 09:07 AM
Posted 07 March 2011 - 09:07 AM
Posted 07 March 2011 - 09:26 AM
Hello Cilfaen and welcome to the UCF!
Refer to page 34 of the FA-124 User's Manual: http://support.casio...04/FA-124_E.pdf
Make sure you installed FA-124 before plugging in your calculator. Follow the instructions and if that doesn't help come back here.
Posted 07 March 2011 - 01:34 PM
Yes, i have already followed the user manual instructions for installing the FA-124 program, but when i try and follow the instructions found in the user manual to import an add-in application, i get the this step :
and cannot continue, because when i get to that point in my program, the only option for file type i get is this :
Edited by Cilfaen, 07 March 2011 - 01:36 PM.
#4 Guest_Guest_*
Posted 08 March 2011 - 07:12 PM
The solution is to click on the rightmost button in one of the two windows inside the FA-124 window before trying to import the add-in.
