Hello all,
I've been doing some programming on my Casio fx-9860 GII.
Since there are only 28 variables (Correct me if I'm wrong), I was wondering if there perhaps is a way to assign a value to a word or create an extra type of variable.
I've tried "LOL 5" but this wouldn't work.
Does anyone know about such a possibility?
Thanks in advance .
Variable Trouble
Nogoodnamesleft
, Mar 17 2011 03:27 PM
Posted 17 March 2011 - 03:27 PM
Posted 03 April 2011 - 06:24 PM
According to my book for the 9750: A-Z, r, and theta are all the variables you can have...can't even split the values to separate programs. If you put a value into A - that value stays there even if you turn off the calculator.
k
k
Posted 04 April 2011 - 03:16 PM
k
Okay , thank you very much .
That kinda sucks though .
I guess I'll just have to live with it .
Posted 04 April 2011 - 03:28 PM
Hello,Since there are only 28 variables (Correct me if I'm wrong),
there are more than 28 variables, you can use variables available under VARS' /> button. For example variable set for right view-window are free in most cases.
You can use 1D arrays (List) or 2D arrays (Matrix).
BTW: if you want to store nuber to a variable, swap value and variable:"5 A"
