How To Prevent Data Copying From/to Classpad 330 Using Another Classpa
Posted 15 August 2012 - 07:50 PM
I'm developing an addin which I need to protect from copying attempts using the USB cable or another, so is there any way to do that?
Many thanks.
Posted 16 August 2012 - 12:44 AM
Posted 16 August 2012 - 05:07 PM
Hello,
Many thanks.
Overwrite the USB code in the OS.
Posted 16 August 2012 - 06:25 PM
The best way, you can create a input box in int main() for write serial key, and then when users submit it this is compared with the serial predefined and if this 2 serials match, addin run, if not You can call a wrong serial message
If you have knowledge to make an add-in, I think it will be easy doing this
Posted 16 August 2012 - 07:41 PM
With a disassembler, it is extremely trivial to make this comparison always return true.
How does one do this?
Posted 16 August 2012 - 11:39 PM
1. Find the USB transfer code in the OS
2. Erase
3. Compute a new checksum
4. Transfer the new OS
Just make sure that you have a cable that works with the 2.5" jack, otherwise you will be unable to transfer a new OS to the calc if you screw up.
Posted 17 August 2012 - 08:32 AM
This is what I call an "anti-solution" :-) How about writing an OS that only includes the written add-in and without transferring ability at all?Overwrite the USB code in the OS.
Posted 17 August 2012 - 11:02 AM
You said that in jest, but that might not be a bad idea at all for the OP!
