Casio fx991ES PLUS autoreset
#1 aedrius
aedrius
    fx-991ES PLUS
Posted 22 December 2016 - 07:48 PM
Hello,
it happened to me twice already. When i turn my Casio fx991ES PLUS  on, it is reset, i have not done that! I have to set everything again, complex numbers, LineIO, memory is deleted. If that happens once a week, I can live with that, but my experience with electronics is, things can get worse, like every day or even during work.
Is it something with batteries? I noticed it happend both times after I moved from place to place. Lower temperatures? Pushing of something on the spot, where batteries are? It is 1,5 years old.
What can be wrong?
VM
#2 frankmar98
frankmar98
  • Moderator
  • 127 posts
  • Interests:Science, programming
    CFX-9970G
    Graph 90+E (fx-GC50)
    fx-9860G SD
    Classpad 300
    HP Prime
    TI-84+ CE-T
    x2 TI-83+
    TI-81
    fx-4800p, fx-3650PII
    fx-991SPX, fx-991ES PLUS, fx-100W
Posted 27 December 2016 - 10:57 AM
This calculator has the settings stored in RAM memory, so if the battery has run down, if you move the calculator to a place without light, the settings will be deleted.
I recommend you to change the battery, it is cheap,
if this don't work, you may want to buy a new calculator
#3 anon34
anon34
  • 268 posts
Posted 28 December 2016 - 10:28 AM
Your calculator being fake is also a possible reason. Also if the battery is low you must have noticed that (low contrast, slow processing, etc.)
