I know that it is possible to checge and add settings with dev c++, so I was wondering. Is it possible to add the SDK makefiles and stuff to the Dev C++ settings so that it can compile G1A addins?
Casio Sdk -> Dev C++
Fez
, Jan 01 2008 03:13 AM
Posted 01 January 2008 - 03:13 AM
Posted 01 January 2008 - 03:16 AM
It is possible, but it may be tricky. The ClassPad SDK uses Dev-C++ as the IDE for the Renesas toolchain. The fx-9860 SDK uses the Renesas toolchain. Maybe if someone studied the ClassPad SDK, they may figure out how to do the same for the fx-9860G. One downside to using Dev-C++ would be lack of the emulator. What I would suggest, is use Notepad++ for editing source files and compile them with the fx-9860G SDK.
Posted 01 January 2008 - 03:22 AM
kool thanx. Ive heard of Notepad++ before but have never actually tried it. Ill give it a go now XD
