Casio Fx-9860g Problem
#1 shabzy
shabzy
    fx-9860G SD
Posted 05 April 2010 - 10:03 PM
I just installed FA-124 and its not reading my calculator, which is a "fx-9860
. When I try to establish a connection, it pops up "No more open file."
I have tried everything, and my link settings are :
Cable Type; USB
Wakeup; On
Capture; Memory
and by the way im on vista
thanks
#2 sweetbob
sweetbob
  • 6 posts
    fx-9860G slim
    fx-4500P
Posted 27 May 2010 - 07:22 PM
thanks
I too had that "No more open file." problem, it is with the USB driver CESG502, but it started working properly when:
I uninstalled FA-124 and then opened the CD that came with the calc, searched the folders.
Found the appropriate Set-up.exe file.
Right-clicked to get the compatiblity box, and ran it under winXP (service pack 2).
After that, it worked properly.
and by the way, I am on win7 pro.
Hope this helps,
sweetbob
