I am going to be buying an FX-991ES soon, and I was wondering what exactly does the two-way power mode mean; that is, if I remove the battery or it drains completely, will the calculator still work, relying only on the solar panel?
Thank you.
Posted 01 May 2010 - 12:33 PM
Posted 01 May 2010 - 06:18 PM
Hey, all.
Posted 03 May 2010 - 03:10 PM
You will not be able to use the calculator when the battery is dead.
I'm not sure what the two-way power means exactly either. Since the battery in the calculator (LR44) is non-rechargable I guess it reduces the battery drain during operation and in standby. (The memory is wiped if the battery is removed).
