Help With Code
#1 Gil
Gil
  • 15 posts
Posted 25 August 2010 - 08:55 PM
Hi
My problem:
I have a Visual Basic problem and i have the code, i want to put this program in my cfx-9850gb, how ?
Code:
Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
Dim landa As Double = Double.Parse(TextBox1.Text)
Dim serv As Double = Double.Parse(TextBox2.Text)
Dim p As Double = Double.Parse(TextBox1.Text) / Double.Parse(TextBox2.Text)
Dim l, lq, w, wq As Double
Dim desocupado As Double = 0
If (p < 1) Then
TextBox3.Text = "Factor abaixo de 1"
l = landa / (serv - landa)
TXTL.Text = l.ToString()
lq = (landa * landa) / (serv * (serv - landa))
TXTLq.Text = lq.ToString()
w = 1 / (serv - landa)
TXTW.Text = w.ToString()
wq = landa / (serv * (serv - landa))
TXTWq.Text = wq.ToString()
desocupado = 1 - p
TextBox8.Text = desocupado.ToString()
Else
TextBox3.Text = "Factor >=1"
End If
End Sub
End Class
any help??
It's to calculate an MM1
Thanks
#2 Scott
Scott
  • 16 posts
  • Interests:I like programing.
    Cfx-9750 GA+ (AKA Cfx-9750 G+)
    Brain (a little faulty)
    Some one dollar piece of *****
Posted 27 August 2010 - 09:47 AM
Hi
My problem:
Code:
If (p < 1) Then
desocupado = 1 - p
Else
End If
End Sub
End Class
any help??
Thanks
Ok i have a 9750 g+ so i can't help you completley but i can tell you that the programming language is similar but not the same. EG you cant have private subs and to end a loop, it is if end or while end not end while. there aren't textboxs in a calculator program. you really have to research a bit and start at the basics to fully understand the difference.
(I use visual basic so i know what your talking about.)
#3 TovAre
TovAre
  • 72 posts
    fx-9860GII SD
    fx-9700-GE
Posted 11 October 2010 - 11:26 PM
This looks quite easy to implement, could you give an example of inputs and outputs for verification.
#4 TovAre
TovAre
  • 72 posts
    fx-9860GII SD
    fx-9700-GE
Posted 11 October 2010 - 11:58 PM
' / -> Division sign
' [Display]  is the display triangle (shift+prgm+F5)
' * is multiplication symbol x
"Landa"?->L
"Serv"?->S
L/S->P
' If statement below, reversed from the original for clarity.
If P>=1
Then "Factor >=1"
Else
"l= ":  L / (S - L) [Display]
"lq= ": (L * L) / (S * /(S -L))[Display]
"w=":1/(S-L) [Display]
"wq=":L/(S*(S-L))[Display]
"desocupado":1-P[Display]
IfEnd
Edited by TovAre, 12 October 2010 - 12:01 AM.
