Draw Sprite Problem (fx-9860g Sdk)
No replies to this topic
#1 Sander in 't Hout
Sander in 't Hout
  • 2 posts
    FX-9860GII
    FX-82ES
Posted 11 September 2010 - 06:01 PM
I'm trying to learn to program using the Casio FX-9860G SDK with revolution-fx 1.0.
But my sprite doesn't display on my calc, although it displays it perfectly on the SDK's emulator.
It also doesn't work on the Casio FX-9860GII manager. The problem seems to be the new OS 2.0 firmware.
How can I make it compatible?
This is the code of the main function:
[codebox]int AddIn_main(int isAppli, unsigned short OptionNum)
const unsigned char sprite1[] = {
0x01, 0xFF, 0xFF, 0x80, 0x03, 0xF0, 0x0F, 0xE0, 0x0F, 0x80, 0x07, 0xF0, 0x1F, 0x00, 0x00, 0xF8,
0x3C, 0x00, 0x00, 0x3C, 0x7C, 0x00, 0x00, 0x1C, 0x78, 0x00, 0x00, 0x0E, 0xF0, 0x1C, 0x1C, 0x0F,
0xF0, 0x22, 0x22, 0x07, 0xF0, 0x41, 0x41, 0x03, 0xF0, 0x4D, 0x4D, 0x03, 0xF0, 0x4D, 0x4D, 0x03,
0xF0, 0x22, 0x22, 0x03, 0xF0, 0x1C, 0x1C, 0x03, 0xE0, 0x00, 0x00, 0x01, 0xE0, 0x01, 0x80, 0x01,
0xC0, 0x01, 0x00, 0x01, 0xC0, 0x03, 0x00, 0x01, 0x80, 0x02, 0x00, 0x01, 0x80, 0x02, 0x00, 0x01,
0x40, 0x03, 0xC0, 0x02, 0x40, 0x00, 0x00, 0x02, 0x40, 0xFF, 0xFF, 0xC2, 0x20, 0xC5, 0x50, 0x44,
0x10, 0x47, 0x71, 0xC8, 0x10, 0x60, 0x03, 0x08, 0x08, 0x30, 0x1E, 0x10, 0x04, 0x1F, 0xF0, 0x20,
0x03, 0x00, 0x00, 0xC0, 0x00, 0x80, 0x01, 0x00, 0x00, 0x30, 0x0E, 0x00, 0x00, 0x0F, 0xF0, 0x00 };
Bdisp_AllClr_VRAM();
while(!FastKeyDown(K_EXIT))
locate(1,4);
Print((unsigned char*)"TEST");
Bdisp_PutDisp_DD();
while(FastKeyDown(K_MENU))
DrawSprite(5, 5, 32, 32, 4, sprite1, SDK_VRAM, WHITE);
Bdisp_PutDisp_DD();
Reset_Calc();
return 1;
}[/codebox]
The code doesn't do much. It displays TEST until the user presses the MENU button. It should then display a sprite until the user releases the key.
