I decided to make a help thread so anyone can post questions about the PrizmSDK/C when they need to.
General Prizmsdk Help Thread
flyingfisch
, May 10 2012 01:00 PM
Posted 10 May 2012 - 01:00 PM
Posted 29 June 2012 - 01:56 PM
OK, need help.
My code:
It's supposed to draw a rainbow across the screen but all it succeeds in doing is freezing my calc. why?
My code:
#include <display_syscalls.h>
#include <display.h>
#include <keyboard_syscalls.h>
#include <keyboard.hpp>
short unsigned int heightcolor(float z, float z_min, float z_max);
void fillArea(int x, int y, int width, int height, int color);
int main(void) {
int ix;
int key;
int color;
int done = 0;
for (ix=1; LCD_WIDTH_PX; 1) {
color = heightcolor(ix, 0, LCD_WIDTH_PX);
fillArea(ix, 0, 1, LCD_HEIGHT_PX, color);
Bdisp_PutDisp_DD();
while(!done) {
GetKey(&key);
switch(key) {
case KEY_CTRL_MENU:
done = 1;
break;
return 1;
short unsigned int heightcolor(float z, float z_min, float z_max) {
float frac = ((z-z_min)/(z_max-z_min));
//color!
float r = (0.25f)-frac;
float g = (0.5f)-frac;
float b = (0.75f)-frac;
//calculate the R/G/B values
r = (r>0.f)?r:-r; g = (g>0.f)?g:-g; b = (b>0.f)?b:-b; //absolute value
r = (0.25f)-r; g = (1.f/3.f)-g; b = (0.25f)-b; //invert
r = (r>0.f)?(6.f*r):0.f; g = (g>0.f)?(6.f*g):0.f; b = (b>0.f)?(6.f*<img src='/dot/public/style_emoticons/<#EMO_DIR#>/cool.png' class='bbc_emoticon' alt='B)' />:0.f; //scale the chromatic triangles
r = (r>1.f)?1.f:r; g = (g>1.f)?1.f:g; b = (b>1.f)?1.f:b; //clip the top of the chromatic triangles
if (frac < 0.25f) r = (r+1.f)/2.f; //adjust the bottom end of the scale so that z_min is red, not black
if (frac > 0.75f) b = (b+1.f)/2.f; //adjust the top end of the scale so that z_max is blue, not black
return (short unsigned int)(0x0000ffff & (((int)(31.f*r) << 11) | ((int)(63.f*g) << 5) | ((int)(31.f*<img src='/dot/public/style_emoticons/<#EMO_DIR#>/cool.png' class='bbc_emoticon' alt='B)' />))); //put the bits together
void fillArea(int x, int y, int width, int height, int color) {
//only use lower two bytes of color
char* VRAM = (char*)0xA8000000;
VRAM += 2*(LCD_WIDTH_PX*y + x);
for(int j=y; j<y+height; j++) {
for(int i=x; i<x+width; i++) {
*(VRAM++) = (color&0x0000FF00)>>8;
*(VRAM++) = (color&0x000000FF);
VRAM += 2*(LCD_WIDTH_PX-width);
Posted 29 June 2012 - 02:11 PM
From answer on IRC channel:
(6:32:55 PM) MicroPro: ffisch: Were you programming in BASIC recently?
(6:32:58 PM) MicroPro: for (ix=1; LCD_WIDTH_PX; 1)
(6:33:00 PM) MicroPro: should be
(6:33:05 PM) MicroPro: for (ix=1; ix < LCD_WIDTH_PX; ix++)
(6:33:52 PM) ffisch: and actually, i was programming in lua recently �4z
Posted 29 June 2012 - 07:58 PM
Hmmm... having problems.
This is supposed to plot a trajectory.
Instead, i plot points all over the screen. I think this is float problem, but could someone take a look at it and tell me if they can see anyhting that is obviously wrong?
#include <math.h>
#include <color.h>
int PRGM_GetKey(void);
void plot(int x0, int y0, int color);
int main(void) {
int main(void) {
//program variables
//program variables
int key;
int key;
int done = 0;
int done = 0;
//graphing variables
float start = 0;
float start = 0;
float t;
float t;
float x;
float x;
float y = 100;
float y = 100;
int h = 2;
int h = 2;
float g = -9.8;
float g = -9.8;
float vy = 0;
float vy = 0;
float vx = 100;
float vx = 100;
char buffer2[10];
char buffer2[10];
for(t=start; t < 2; t += 0.01) {
//y = h+0.5*g* t*t + vy*t;
//x = vx*t;
//x = vx*t;
x = vx*t;
x = vx*t;
y += vy;
y += vy;
vy -= 9.8;
vy -= 9.8;
//start debug
//start debug
strcpy(buffer2," ");
itoa(x, buffer2+2);
itoa(x, buffer2+2);
PrintXY(3, 1, buffer2, TEXT_MODE_NORMAL, TEXT_COLOR_BLACK);
itoa(x, buffer2+2);
itoa(x, buffer2+2);
PrintXY(3, 2, buffer2, TEXT_MODE_NORMAL, TEXT_COLOR_BLACK);
PrintXY(1, 1, " X", TEXT_MODE_NORMAL, TEXT_COLOR_BLACK);
PrintXY(1, 2, " Y", TEXT_MODE_NORMAL, TEXT_COLOR_BLACK);
//end debug
//end debug
plot(x, LCD_HEIGHT_PX - y, COLOR_BLACK);
Bdisp_PutDisp_DD();
Bdisp_PutDisp_DD();
while(!done) {
while(!done) {
key = PRGM_GetKey();
switch(key) {
switch(key) {
case KEY_PRGM_MENU:
case KEY_PRGM_MENU:
done = 1;
done = 1;
break;
break;
return 1;
return 1;
//routines
//color!
//color!
int PRGM_GetKey(void) {
unsigned char buffer[12];
PRGM_GetKey_OS( buffer );
return ( buffer[1] & 0x0F ) * 10 + ( ( buffer[2] & 0xF0 ) >> 4 );
void plot(int x0, int y0, int color) {
VRAM += 2*(y0*LCD_WIDTH_PX + x0);
return;
return;
//my routines
Posted 01 July 2012 - 06:37 PM
hmm, i am still working on this.
I think there is something i dont know about floats.
can you see a math error in function plotBallistics?
#include <math.h>
#include <color.h>
void plotBallistics(float start, int startHeight, int endHeight, float vy, float vx, int color);
int PrintMiniFix( int x, int y, const char*Msg, const int flags, const short color, const short bcolor );
void mainGUI(char*cartridge);
int main(void) {
int key;
int done = 0;
mainGUI(".22");
Bdisp_PutDisp_DD();
while(!done) {
switch(key) {
case KEY_PRGM_MENU:
done = 1;
break;
return 1;
//routines
//color!
return;
int PrintMiniFix( int x, int y, const char*Msg, const int flags, const short color, const short bcolor ){
int i = 0, dx;
int empty;
unsigned short width;
void*p;
while ( Msg[ i ] ){
p = GetMiniGlyphPtr( Msg[ i ], &width );
dx = ( 12 - width ) / 2;
if ( dx > 0 ) {
PrintMiniGlyph( x, y, (void*)empty, flags, dx, 0, 0, 0, 0, color, bcolor, 0 );
}else dx = 0;
PrintMiniGlyph( x+dx, y, p, flags, width, 0, 0, 0, 0, color, bcolor, 0 );
if ( width+dx < 12 ){
PrintMiniGlyph( x+width+dx, y, (void*)empty, flags, 12-width-dx, 0, 0, 0, 0, color, bcolor, 0 );
x += 12;
i++;
return x;
const short empty[18] = { 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 };
//my routines
void mainGUI(char*cartridge) {
//background
fillArea(0, 0, LCD_WIDTH_PX, LCD_HEIGHT_PX, (color_t)0x3333);
//graph
plotBallistics(0, 100, 40, 0, 300, COLOR_ORANGE);
//bars
//bottom
fillArea(0, LCD_HEIGHT_PX - 50, LCD_WIDTH_PX, 50, COLOR_BLACK);
fillArea(0, LCD_HEIGHT_PX - 51, LCD_WIDTH_PX, 1, COLOR_GRAY);
//top
fillArea(0, 0, LCD_WIDTH_PX, 25, COLOR_DARKBLUE);
fillArea(0, 25, LCD_WIDTH_PX, 1, COLOR_GRAY);
//buttons
//cartridge
fillArea(5, LCD_HEIGHT_PX - 40, 100, 30, COLOR_DARKRED);
PrintMiniFix(7, LCD_HEIGHT_PX - 55, cartridge, 0, COLOR_WHITE, COLOR_DARKRED);
//go
fillArea(LCD_WIDTH_PX - 55, LCD_HEIGHT_PX - 40, 50, 30, COLOR_DARKGREEN);
PrintMiniFix(LCD_WIDTH_PX - 45, LCD_HEIGHT_PX - 55, "GO", 0, COLOR_WHITE, COLOR_DARKGREEN);
void plotBallistics(float start, int startHeight, int endHeight, float vy, float vx, int color) {
float t;
float x;
float y = startHeight;
//x = vx*t;
x = vx*t;
//x /= 10;
y += vy;
vy -= 9.8*t;
if(y<0) {
break;
y += endHeight;
plot(x, LCD_HEIGHT_PX - y, color);
fillArea(x, LCD_HEIGHT_PX - y, 4, 4, color);
Posted 06 July 2012 - 12:01 PM
floats' precision is usually enough for these small number so no need to worry.
There is, as you guessed, an error in plotBallistics. You are adding 140 to y in each iteration:
Instead of:
you should have:
Instead of:
y += endHeight; plot(x, LCD_HEIGHT_PX - y, color); fillArea(x, LCD_HEIGHT_PX - y, 4, 4, color);
you should have:
//y += endHeight; plot(x, LCD_HEIGHT_PX - (y + endHeight), color); fillArea(x, LCD_HEIGHT_PX - (y + endHeight), 4, 4, color);
