Difference Between Different Versions Of 9860Gii
#1 grob103
grob103
  • 4 posts
Posted 10 March 2015 - 05:19 PM
Hi!
I am a newbie on this forum. I am considering buying a 9860GII but am confused at the different models/versions. On Casio website, I have found
- 9860GII (with the image showing the label "USB Power Graphic").
- 9860GII S (image showing "USB Power Graphic 2".
- The pink model 9860GIIPK also has an image of Power Graphic 2 on Casio site.
I am researching used items online and found someone selling 9860GII but with USB Power Graphic 2.
Can someone please explain the differences? Is it true that only the USB Power Grapic 2 models have more powerful SH4 processors? Or only the Graphic 2 has vector functions?  Thanks!
Edited by grob103, 10 March 2015 - 05:21 PM.
#2 sentaro21
sentaro21
    Casio Technician
  • PipPipPipPipPipPip
  • 369 posts
    FX-603P fx-4800P fx-5800P
    CFX-9850GC PLUS
    fx-9860G
    fx-9860GII
    fx-9860GII-2
    fx-9860GII-2 SD
    fx-CG10
    fx-CG20
    fx-CG50
    HP-Prime
    HP 50G
    TI-Nspire CX CAS
    TI-84+CE
Posted 14 March 2015 - 01:01 PM
Hi! grob103 :)
"USB Power Graphic " is SH3 model
"USB Power Graphic 2" is SH4 model
There is no fully compatible of add-in.
yes.
vector functions is OS 2.04 feature both of SH3 and SH4.
Edited by sentaro21, 14 March 2015 - 01:15 PM.
#3 Krtyski
Krtyski
  • 132 posts
  • Interests:programming, smooth Jazz and 4-wheel driving.
    FX-502P, FX-602P, FX-603P,
    fx-4000P, fx-7000G,
    fx-4500P, fx-4800P
    fx-5800P,
    CFX-9850G,
    CFX-9850GC PLUS
    fx-9860G,
    fx-9860G AU,
    fx-9860G Slim
    fx-9860GII SD,
    fx-9860GII-2,
    fx-9860GII-2 SD,
    fx-CG20, fx-CG50,
    fx-CP400
    fx-9860GIII
    fx-9750GIII
    fx-7400GIII
Posted 20 March 2015 - 10:06 AM
If you really want high speed operation with fx-9860GII, I recommend "USB Power Graphic 2" model. if you use over-clocking add-in, you can enjoy more than 230MHz, this is much higher than normal clock 29MHz). I use Ftune2 created  by sentaro21 (he gave you comment above). We can download this add-in in this forum.
If you enjoy C programming with CASIO SDK, it does not fully support "USB Power Graphic 2".
But I think you can cope with this. So at this time I think "USB Power Graphic 2" is the best.
