small abc
Guest_juggler_*
Posted 20 December 2003 - 04:12 PM
greetz,
juggler
ps. It's my first post
Posted 20 December 2003 - 04:17 PM
anyway, the only way to get lowercase letters is to send them to the calculator, using FA123, and then copying them into the program, a very long task on the CFX, as it dosn't have the Copy and paste function that the AFX has/
your best bet is to write the prog on the PC and download it to your calc, if you need a PC to Calc cable, check my site casiofortissimo
the unofficial cable is easyer and more common to build
hope this helps
Posted 20 December 2003 - 04:21 PM
Guest_juggler_*
Posted 20 December 2003 - 04:29 PM
greetz,
juggler
Posted 20 December 2003 - 04:35 PM
Open a file,
type all lowercase letters (a-z) in and send it to the calc.
Now go to PRGM Menu and open the file.
Press OPTN -> FMEM -> STORE -> f6
No go to run menu
press OPTN -> FMEM -> RCL -> f6
Delete all letters except abcd now do OPTN -> FMEM -> STO -> f1
do the same with all other blocks (e-i ,...) and use f2-f6 for them.
(You must use f6 last since you overwrite the alphabet afterwards.
No you can copy the letters in you program by
using OPTN -> FMEM -> RCL and the corrseponding memory in the
PRGM Menu.
This is quite difficlt and it might be better to write you programs with upper case
and then copy them to the PC, replace the upper case characters with lower case ones
and send it back to the calc.
Guest_juggler_*
Posted 20 December 2003 - 04:36 PM
greetz,
juggler
Posted 20 December 2003 - 04:37 PM
Guest_juggler_*
Posted 20 December 2003 - 04:40 PM
( I didn't even know that fa-123 has an edit function)
greetz,
juggler
Posted 20 December 2003 - 04:50 PM
Posted 21 December 2003 - 07:31 AM
@juggler, FA-123 has a calculator and CasioCom has an emulator!
Guest_juggler_*
Posted 21 December 2003 - 10:23 AM
Does one of you know how that screen capture function of fa-123 works? I can click the picture on the toolbar but then? It stays on 0%.
greetz
juggler
Posted 21 December 2003 - 10:31 AM
menu and have to enable screenshots (Don'T remember the exact name).
After you did this connect PC->CALC
and now select capture on fa-123 and then press [F->D] on the calc.
Thats it
Guest_juggler_*
Posted 22 December 2003 - 12:12 PM
greetz juggler
Posted 22 December 2003 - 02:53 PM
There is a mneu point for screenshots.
Where are the CFX owners? Help us!
Posted 22 December 2003 - 03:42 PM
- open your Fa-123
- select screen capture (this is the part your stuck at correct?)
- hit [F<->D] to take the picture
Posted 22 December 2003 - 08:15 PM
on calc:
go into LINK (on the main menu)
press
exit all of the menus, run the prog you want to capture then
on you PC press (in fa-123) screen capture (you will get the 0% dialogue)
on the calc, press [F<->D]
the PC will now recive the screenshot
Guest_juggler_*
Posted 23 December 2003 - 10:10 AM
thx to all of you. I think, I don't hope, I need you again sometime.
greetz,
juggler
Posted 23 December 2003 - 08:42 PM
Guest_Axel_*
Posted 07 February 2008 - 09:45 PM
I was wondering if I could program the letters in the calculator.
Eg. if I could program the letter G to 6,67 x 10(-11) (the gravity constant), and than type G in an example instead of writing the whole constant like when I type phi, the calculator knows that I really mean 3,14.
Can anyone help me?
