Degrees, minutes,seconds
Posted 26 October 2002 - 03:17 PM
Posted 26 October 2002 - 03:44 PM
I take it you are very familiar with those kind of transforms anyway, since you need to work with them. The calculator will store any value as a decimal, nomatter what you transform it to. the difference is only how you display it.
If you need to feed big chunks of data in this format into your calculator, I suggest you make a program that lets you input the values and change them for you, maybe storing them in a list or something.
This was probably not too helpful, so please reply and further explain your problem.
Posted 26 October 2002 - 09:15 PM
If one enters an angle in HP format (i.e. ddd.mmss) then press the - ' " function you get a - after the number and it doesn't convert the angle to decimal. The inverse function works fine, however.
Anyone know the proper syntax of the function?
Posted 27 October 2002 - 10:04 AM
if you want to convert 63? 15' 3" than you have to press in (Run-Menu)
1. 6
2. 3
3.
4. 1
5. 5
6.
7. 3
8.
9.
and you have it convertet. to convert it back press
this should work with all calculators from casio!
bye
rstweb
Guest_Guest_John_*_*
Posted 27 November 2010 - 08:04 AM
Hi guys well i bought the casio fx-9860Gii
but it seems that i cant find the degree/minutes/seconds things
im trying to solve this proble tan15degree30'50".
i know the answer but i dont know how to find it in the calculator..
like what button do i have to click.
so furstarted trying to find this button for over one week
i looked through the ineternet and asked bunch of people but they all said
i should have bought the Ti-84
anyway now i need your help
Posted 27 November 2010 - 08:11 AM
well i know taht i have to go to options then f6 and then f5 thats where i will find my degree button but what about the rest.......Hello,
(im the same guy)
Guest_Guest_Rachel_*_*
Posted 12 June 2011 - 08:08 AM
it's above the ENG button, I hope i'm talking about the right thing
