Passwords for Progs
Posted 11 February 2004 - 01:09 PM
Guest_juggler_*
Posted 11 February 2004 - 05:28 PM
Posted 11 February 2004 - 05:56 PM
Posted 11 February 2004 - 06:43 PM
Posted 11 February 2004 - 07:28 PM
on 9850 GB PLUS:
Main menu => program => F6 => F5 ("Load")
Posted 11 February 2004 - 08:39 PM
Posted 12 February 2004 - 07:32 AM
Posted 12 February 2004 - 02:09 PM
And there is a method to find the passwords. it takes about 10 minutes ...
Posted 12 February 2004 - 02:56 PM
Posted 12 February 2004 - 05:28 PM
put this in your new prog : DrawDyna
Then go on the Dyna icon
enter AX in Y1 for exemple
then select Y1 and no other ones!
F2 ->start 1, end 2
now go on the icon "MAT"then crate a matrix as big as possible
and the launch your program CRACK
when you see the function on the screen -> AC/ON
wait a moment
when you see a program named 1010101010 on the screen
hold down the key
when you see the name of the program (it is written the last letter first etc ..)
the password is near! (always written with the first caracter at the end etc ..)
do you understand???
Posted 12 February 2004 - 07:08 PM
You can load the progs, then transfer a backup to FX-Interface Professionnal, there is a option to see/delete/change the password of a prog
Posted 12 February 2004 - 07:21 PM
Posted 12 February 2004 - 08:57 PM
Posted 12 February 2004 - 09:51 PM
Posted 13 February 2004 - 09:02 AM
There have been thousands of lists on the Internet from ages ago. Many people HAVE figured it out by 5 years ago.You would think someone would have figured it out by now...
Guest_juggler_*
Posted 13 February 2004 - 06:21 PM
Guest_juggler_*
Posted 14 February 2004 - 10:23 AM
Who can help me on those passwords?
[neo]f4kill wrote:
"make a program and call it CRACK for exemple
F2 ->start 1, end 2
wait a moment
hold down the key
do you understand???"
Does that also work on my CFX-GB9850-PLUS?
Posted 14 February 2004 - 06:23 PM
And I don't know if they are the same ..
but the g65 is the only one which have a library of programs ...
Yes I think it'll work on your calc ... (it works on differents calcs)
Posted 14 February 2004 - 06:50 PM
juggler : try to transfer all the progs to the computer
Guest_juggler_*
Posted 14 February 2004 - 07:30 PM
I tryed out with different Matrices and I got the password of some of the progs.
I couldn't transfer them to the pc because you need a password before it transfers ( at least with Fa-123)
Posted 14 February 2004 - 09:59 PM
Posted 14 February 2004 - 11:52 PM
#25
Guest_juggler_*
Posted 15 February 2004 - 11:12 AM
The progs in my library have other titles than the lists on those sites you gave me, but that method to find the passwords does works.
#26
Posted 15 February 2004 - 03:52 PM
the g65 has a 128x64 pix screen, library, colors 'orange-blue-green', financial mode and 64ko.
you can see some pictures (25,35,35+,65,65+,100,100+) here : http://www.casioland.net/modeles.php
#27
Guest_juggler_*
Posted 16 February 2004 - 07:12 AM
I know for 99% sure that cfx-9850GB-plus=g65+ OR =g35+
but there is not much difference between those two, is it?
#28
Posted 16 February 2004 - 07:36 AM
note : my g60 has written on it : CFX-9940 (GT ?) and i never understood the CFX numbers...
#29
Guest_juggler_*
Posted 16 February 2004 - 10:36 AM
? call it cfx-9850GB-plus because that's written on mine, but it must be g65+ because it has collors.
#30
Guest_DCreator_*
Posted 25 April 2006 - 01:35 AM
Offcourse, you can find all passwords here for example:Does anyone know any of the passwords to the Library of programs on the CFX?
http://www.tek-tips....id=43698&page=2
If the link is broken:
Library Program Password
AUSTRALIA
BINPROB 60731404
D.E.PLOT 63976224
DIFFLIST 96104555
DIRECFLD 45481618
MANDLBRT 20397551
EA-100
ACCELA 23954441
BAR V,A 94165850
BREATH 14466249
CALIPERS 41644774
DISPLAY 54589197
DISTANCE 48878266
ELECHARG 92284670
ELEPOTSF 55419117
FREEFALL 17292972
LIGHTINT 85825899
LISSAJOU 62546043
MELTPNT 96705163
PENDULUM 80814130
PHMEASUR 21714660
PNT V,A 69982749
TEMPTIT 83438432
JAPAN
CAOSI1 26613350
CAOSI2 5264787
CAOSI3 1983925
CAOSI4 10658879
CMN 15048317
FACT 13409420
IFPLOT 34303255
ROTATE 31739453
SAFESET1 57113390
SAFESET2 59356071
SAFESET3 11275656
SAFESET4 32103669
T TEST 43933862
TANGENT 52765601
CIRCLE 70515172
WINDOW 50639612
TRANSFER 95596108
SPAIN
NM-O-I 94564707
NM-O-I-B 51763917
I 66430021
O 50508634
OIB 94881934
NMAND2Z 61931639
OUT 30376957
NMAND3R 81614988
CLR X 36806206
CLR Y 22361844
DX 86898419
DY 56609893
IN 53233282
PWP 25197075
U.S.A
AMORTIZE 33269833
BONDMAIN WARNER
BONDCHNG WARNER
BONDSOLV WARNER
BONDCALC WARNER
BONDDISP WARNER
BONDMORE WARNER
JULIAN WARNER
CALDAY WARNER
ACTDAY WARNER
360DAY WARNER
PRCSHRT WARNER
YLDSHRT WARNER
PRCLONG WARNER
YLDLONG WARNER
PPRIME WARNER
CMPLXPWR 47337884
CMPLXRT 26492632
DBLINT 22271276
EULER 91090636
FORECAST WARNER
EXPS WARNER
HOLTWINT WARNER
ST2GRPH WARNER
ERROR WARNER
ERR.DISP WARNER
FUNDTHM 75946918
IMPGRAPH 55183261
LINPROG 48369213
PRIME 69944734
RIEMANN 71219714
ROWREDA 97561356
SLOPEFLD 62313046
TRIPLINT 21045083
TVMMAIN WARNER
TVMCHANG WARNER
TVMDFDZ WARNER
TVMFUN WARNER
TVMGRAPH WARNER
TVMPANEL WARNER
TVMPICKX WARNER
TVMPICKY WARNER
TVMSETZ WARNER
UK
FIBGEN 43533508
TRI 25296384
