solve()
8 replies to this topic
#1 Gerard
Gerard
  • 5 posts
    classpad 300
Posted 19 February 2004 - 09:08 PM
?'m really new in this about calculators (2 weeks) then:
have been trying to make a program and I need to isolate the result of a solve function, i get a result as {x=0.020615} to put it into a variable ant then make some operations, with this result I cant operate.
Is there any other function as eval() or similar to get only the expression? or any trick?
I've been trying to convert to a string eliminate "x=" and then use the strtoexp() but it doesn't change the type... :banghead:
excuse my english, thankyou!
P.S. :What is the difference in use this [(-)] and this [-]
#2 Daniel (CZE)
Daniel (CZE)
  • 74 posts
  • Interests:Support for Pocket Viewer and ClassPad for Czech Republic.
    ClassPad 300, TI-92 Plus, FX-6300G, CFX-9850GB Plus
Posted 19 February 2004 - 10:20 PM
As you can see, result is given as list type. So you can do something like this:
solve(x=1,x)=>y
In var. y is the result {x=1}
now you can operate with expr. in var. y as with list.
You can access to result by this command: y1
If you have more expressions ({x=1,x=-1}), you can use y1, y2, ...
"(-)" and "-" is same, I think.
#3 Andy.Davies
Andy.Davies
    Forum Ghost
  • 1547 posts
  • Interests:Age: 18
    Studying: MEng in cybernetics at Reading uni
    Interests: Progaming (VB, VB.Net, C#, Casio Basic)
    Computers UBBD (Using, Building, Breaking & Destroying)
    Gaming (FPS, RTS, RPG)
    Electronics
    Rock Music (Preferably Loud)
    Riley's (Pool & Snooker Bar)
    Driving (Preferably fast)
    Aikedo (Martial Art)
    Algebra FX 2.0 ROM 1.01, FX9750G
Posted 19 February 2004 - 10:25 PM
yes i belive they are:
<span class=3' /> [+] [-] <span class=2' /> = 1
<span class=3' /> [+] [(-)] <span class=2' /> = 1
aswell, with no syn errors, so i guess they are the same
#4 Daniel (CZE)
Daniel (CZE)
  • 74 posts
Posted 19 February 2004 - 10:47 PM
You can get left or right part of expression ("=" is center) by these commands:
getLeft(EXPR)
getRight(EXPR)
so for "x=1" you'll get number 1 as: getRight(x=1) :)
#5 CrimsonCasio
CrimsonCasio
    UCF Ambassador
  • PipPipPipPipPipPipPipPipPipPip
  • 3579 posts
  • Interests:Claculators, Stephen King, Video Games, Calculators, Programming, Calculators, Reading, Calculators... hmm, what else... Ah! Calculators!
    Algebra FX2.0, CFX 9850Ga+, Classpad 300
Posted 19 February 2004 - 11:09 PM
another way you could do it is like this:
solve(EQU,x)=>y
ExpToStr y,y //y is now a string
StrFind y,"=",smin
StrFind y,"}",smax
StrMid y,smin+1,y,smin-1 //the # part the y is stored in y
strToExp(y)=>y //y is a number
this is the programming method, in this case the mathmatical way is better.
#6 mkanter
mkanter
  • 74 posts
    CFX9850G, ClassPad 300
Posted 20 February 2004 - 11:15 AM
To get the expression (the right side of the solution you can use getRight and need not to look for the =)
solve(f(x),x)=>sol
'to make expr the same size as sol
sol=>expr
'The first expression
getRight(sol1)=>expr1
'The 2nd expression - if there is one check it with dim(sol)
getRight(sol2)=>expr2
'The 3rd expression- if there is one check it with dim(sol)
getRight(sol3)=>expr3
#7 Gerard
Gerard
  • 5 posts
    classpad 300
Posted 20 February 2004 - 03:38 PM
It's great to have an answer as wide as this :thumbsup:
Ive been trying the getright() and it's what I needed.
Thankyou.Best regards :D
#8 CrimsonCasio
CrimsonCasio
    UCF Ambassador
  • 3579 posts
Posted 20 February 2004 - 04:28 PM
good luck :)
#9 tonyp
tonyp
  • 34 posts
    TI89, TI89 Titanium, TI-nspire CAS, Casio ClassPad300, Casio fx-6300g, Casio GFX9850GB, Casio 82ES, more
Posted 25 February 2004 - 05:46 PM
solve(x=1,x)=>y
By the way, this also works with ANS so you don't have to save the result to a variable, if it's to be used only once afterwards.
ANS1 will return the first list item. ANS2 the second, and so on.
tonyp AT acm.org
