Help-problem With Brand New Classpad
Posted 02 March 2004 - 06:23 PM
Does anyone know what I should do?
Posted 02 March 2004 - 06:52 PM
turn it off, then hit [on/off]
Posted 02 March 2004 - 07:21 PM
I just tried it and the display shows more this time but the battery indicator is not completely showing. Also when I hit keyboard button or any do anything else the screen gets messed up again.
Posted 02 March 2004 - 08:20 PM
Place your classpad gently on the table.
Move your feet apart about the same distance as the width of your shoulders.
Grab the stylus, and hold it firmly with both hands, and the tip pointing down.
Extend your arms fully.
Position you (or the classpad) such that the stylus touches the center of the screen, still with your arms fully extended.
Now, rais your arms above your head.
Take a deep breath, and hold it for 5 secconds.
SMASH your stylus down with all your power, exhaling and screaming like a madman.
Call tech support, and tell them you have problem with an unfunctional classpad.
Posted 02 March 2004 - 08:51 PM
It seems as though the classpad was dropped but there no sign of damage.
I hope I don't have to return it
Posted 02 March 2004 - 11:02 PM
oh, in the mean time try initializing the memory.
Posted 03 March 2004 - 07:36 AM
I've tried initializing( a few times), resetting but it seems to be a serious LCD and/or microchip problem. I really think its a faulty component and one that will most likely need replacing.
No matter what I do the it keeps showing a couple of black strips running vertically and and a couple of strips that run vertically as well but is blank in the strip.
Posted 03 March 2004 - 10:05 AM
i did the following (resetting don't help)
Put the batteries in (maybe buy some new)
turn on (if it not automaticly to it)
turn off
take the batts out
turn on !!! this will reset the memory too (hold the on/off key 2-3 sec.)
wait about a day.
(then it worked.)
if this not helps you may have to send it in (and hope an other firm will carry it to you)
www.mkanter.de.vu
Posted 03 March 2004 - 11:45 PM
I've tried that but the lines still show up.
The more I read the topics in this forum the more I suspect that it might be a bug or OS problem. So, I'm going to try to upgrade the OS.
Please keep any advice or suggestions coming because I doubt that I will have the problem fixed anytime soon.
