I believe my AFX 2.0's problem is in the flash memory (i wanna test my theory) but, will AFX 2.0 work without the flash chip?
<_< (if not, i'd better start looking for a new chip, before attempting to remove the probably damages flash chip)
Will AFX 2.0 work without the flash chip?
MathManiac
, Nov 11 2002 04:24 PM
7 replies to this topic
Posted 11 November 2002 - 04:24 PM
Posted 11 November 2002 - 04:30 PM
i think no. because the casio is nearly a computer. i think you would get an error at starting. some build-in programs of casio use the flash chip. i think it wouldn't be so difficult to find such a chip.
bye
rstweb
bye
rstweb
Posted 11 November 2002 - 04:36 PM
yes, some applications/menus may not work, but the calc will work? (has already someone tried?) ...I dont know if i will find such a chip here, in Madeira Island. Sometimes its hard do find some stuff.
Posted 11 November 2002 - 06:30 PM
technically no
Because the flash is used by the startup & the menu
Every move into the menu reads in the flash, every program launched reads in the flash
all this bacause command.com and the driver are in the flash 1st segment
Also the menu icones are in this segment
Posted 11 November 2002 - 08:48 PM
unfortunately that confirms my theory: the problem is in my calc's flash.
So i really have to get a new chip!
Posted 11 November 2002 - 09:23 PM
if you want to buy a new chip then search at www.google.com for the Chip-Manufacturer and Chip-Type. In most of the cases you will find a distributor or a shop where you can buy such a chip.
bye
rstweb
bye
rstweb
Posted 12 November 2002 - 12:35 PM
...i think the postman is already tired of reading my name in packages! (and i am tired of paying shipping costs)
Posted 16 November 2002 - 07:58 AM
As a last resort, you might be able to use a ROM chip or incompatable flash chip with the right contents for the system segment, and the calc should at least boot and let you do non-flash stuff. Installing extra programs gets difficult at that point though...
