Hi guys. I'm a frustrated newbie who really has been reading the manual. But there are some very simple things I can't seem to figure out to do.
For example, if I want to find out that the sqrt(2) is 1.4142135... How do I do it? I can only get my results to remain in symbolic/algebraic form. Is there a menu option somewhere or a mode to get the numeric answer? I've tried everything I can think of.
Sorry to ask such a basic question, but it's important to me that an advanced calculator does the easy, everyday things fast and simple.
As a PS, has anyone managed to write assembly code for the CP? I know it's not as open as the TI...
- Jeff
Newbie Help - How To Use Cp As Calculator?
CPHopeful
, May 03 2004 01:58 PM
Posted 03 May 2004 - 01:58 PM
Posted 03 May 2004 - 02:28 PM
in the menu settings : basic format : turn on decimal calculation to have the numeric answers for all operations until you turn it off
to convert only the last answer in the other (unactive) format : clic on the first icon (0.5 <-> 1/2) then exe
Posted 03 May 2004 - 03:00 PM
Thank you very much for the help. At first I could figure out which icon you meant, but now I see it up there in the upper left and everything works great!in the menu settings : basic format : turn on decimal calculation to have the numeric answers for all operations until you turn it off
Looks like there may be quite a learning curve on this baby.
Posted 03 May 2004 - 03:04 PM
You know, here's a great suggestion from us Newbies for future classpads.
Since there's no way to "hover" with a stylus, it would be great to add a HELP button such that if you hold the help button and tap on any button or icon, you get a description of what that button does. The help could even appear in its own mini window.
Having a built in help would really be worth a lot in terms of getting people into the CP300 features, and since the CP300 already has more memory than any other calculator, they can afford better help than anyone else.
- Jeff
- Jeff
Posted 03 May 2004 - 05:03 PM
I doubt this will happen but i guess its possible casio could release a helper add-in.
anyway, if you have anymore questions just ask here
