hi every body... i have downloaded this software to instal some proframs but i can?t conecct mi CP with my PC... what can i do
Also i have conected my CP with my PC, so then i can change some archives but with this new program i can`t conected them...
what can i do...????
thx
Help!
virgum
, May 07 2004 03:20 AM
Posted 07 May 2004 - 03:20 AM
Posted 07 May 2004 - 05:39 AM
Hi.
To use Addin installer:
-Turn off "Wake up" function.
-Connect cable.
-In Communication ( on ClassPad ), go to Link-Install-Addin.
-On computer, start Addin installer and click button "Connect".
My English is not good. Could you please explain more about the second question ?
-Connect cable.
Posted 07 May 2004 - 09:34 AM
In Lovecasio`s list the 3. point is the important:
"-In Communication ( on ClassPad ), go to Link-Install-Addin."
You can`t connect to the ClassPad Add-In Installer by using the send or receive
button on your Classpad.
