Hi guys
i just bought a new AFX 2.0 plus. The problem that i face is that whenever i perform a simple calculation in the CAS mode, for e.g say 5/2, it displays the answer as 5/2 only and not as 2.5. I'd lik 2 know as to how this setting can be changed.
Kindly mail me at abhishta1 AT indiatimes.com.
CAS mode problem
abhishta
, Nov 21 2002 07:18 AM
Posted 21 November 2002 - 07:18 AM
Posted 21 November 2002 - 11:39 AM
You should read your manual
The CAS system has benn designd to give accurate answer so you cannot change that. However their is command called "Approx" at the top of the
F1' /> menu that gives what you want.
Posted 22 November 2002 - 01:54 AM
Ah well, thats part of what this fourm is for isnt it, but 2072 is right you really should read your manual before posting here. As for your question you should use the normal RUN mode if you want your answers to be decimile form.
