Input Value's for Letters Quicker
Posted 13 December 2002 - 03:21 PM
I also have to make tables with these, so I use run and then type
0,1 -> D (for example)
I then use the letters in table.
But some formula's have 7 or 8 letters that I have to fill in, so I insteading of going through all that for every sum, I was wondering If there is a program that asks me to fill in the value's.
Like this :
D = ?
L = ?
F = ?
I fill em in, hit enter, so that all the value's are stored under those letters. This way I can use them in table.
etc, is it possible?
(ow yeah, I have the Casio CFX-9850 PLUS)
Posted 13 December 2002 - 04:07 PM
and type F3 to create a new Program.
Then type in the filename e.g. Question and Hit
Now Type for every variable you want to assign a value to
"Text "?->Variable
Then press exe to go to a new line
So to enter the diameter type
"Diameter"?->D
You get the sign " using
and the sign ? using
That's it! Just run the program and enter the data!
Now it's assigned to the Variables
Now just run the Program
Posted 13 December 2002 - 05:31 PM
I'm typing it in now, maybe its just me, but I can't seem to find the "?" (question mark), under which button is it?
Posted 13 December 2002 - 05:34 PM
Oops sorry you said it already, sorry, I'm gonna typ it in and see if it worksThanks for the reply huhn.
Posted 13 December 2002 - 05:44 PM
Maybe this is pushing it, but is it also possible to fill in the formule itself.
So you fill in the values, and then it calculates it?
formule is pressure loss = Fx(L:D)x0,5xRxV2
reason why I ask is cause we use this about a trillian times a day
Posted 13 December 2002 - 07:25 PM
Posted 14 December 2002 - 11:38 AM
Now I'm at it, is it possible to have it say, Pressure loss = answer, instead of just the answer? Or maybe you have a site with a little explanation on how I can find these things out for myself?
Thanks in advance!
Posted 14 December 2002 - 12:21 PM
PREASURE=
1x10^5
Pa
that would be done by typing
ClrText *(only myfingers knw whre2find this - &my calc is missing)
"PREASURE="
P *(P is the variable u used 4 preasure+
"spacex19Pa" *(where space means guess what? I'm fairly sure spaces are right)
alternatively if you have one of the mentioned calcs u can do
ClrText
"PREASURE="
Locate X,1,P *(again P preasure - you'll need to play with x remember you've still got the units to put in so you'll need the last two places free,if u want 10d.p. otherwise just leave it
Locate 19,1,"Pa"
Please note you can only get small case letters if you send them down from a computer - if you want to use Pa you'll probibly have to write PA
Posted 14 December 2002 - 12:36 PM
This is what I have so far :
"FRICTIONFACTOR"?->F [enter]
"LENGTH"?->L [enter]
"DIAMETER"?->D [enter]
"K-VALUE"?->K [enter]
"DENSITY"?->R [enter]
"SPEED"?->V [enter]
(FxL:D+K)x.5xRxV2[disp triangle]
(so far it works, then I added;)
ClrText [enter]
"PRESSURE="
(here I'm stuck, I don't really know what you mean with Local X,1,P, etc)
Posted 14 December 2002 - 01:13 PM
Don't us the disp triangle line
Instead type
(FxL:D+K)x.5xRxV2->P
'Use this to assign the pressure to P
ClrText
'Clear the screen
Locate 1,1,"PRESSURE="
'Write the word Pressure to Column 1 Line 1
Locate 10,1,P
'Now output P after the word (line 1,column 10)
This should do it!
If you see the word DONE. overwriting your result you should replace the
triangle by
Do:LpWhile GetKey<>32
This will wait until the minus sign is pressed (KeyCode 32)
To find the commands you may result your manual(!)
Some tips:
1. You insert text in a line by pressing
Press the same again to resume overwriting or
simply move your cursor
2. You find an index of all keycodes of the calc in the programming part
of the manual
3. All lops and while and For loops are stored in
Posted 14 December 2002 - 01:15 PM
eg: to assign pi to p type
3.1416->P
Posted 14 December 2002 - 01:18 PM
"SPEED"?->V [enter]
ClrText [enter]
"PRESSURE="[enter]
That should be the correct order. Now "Locate" prints a text or a variable at a fixed point of the display, which has 21 columns and 7 rows for text to be displayed. A cool programmer would do this:
ClrText[enter]
" "[enter]
Locate 1,1,"FRICTIONFACTOR"[enter]
?->F[enter]
ClrText[enter]
" "[enter]
Locate 1,1,"LENGTH"[enter]
?->L[enter]
ClrText[enter]
" "[enter]
Locate 1,1,"DIAMETER"[enter]
?->D [enter]
ClrText[enter]
" "[enter]
Locate 1,1,"K-VALUE"[enter]
?->K[enter]
ClrText[enter]
" "[enter]
Locate 1,1,"DENSITY"[enter]
?->R[enter]
ClrText
" "[enter]
Locate 1,1,"SPEED"?->V[enter]
ClrText [enter]
Locate 1,1,"PRESSURE="[enter]
Locate 10,1,(FxL:D+K)x.5xRxV2
Try this out. It will be a lot faster because of the usage of locate.
Posted 14 December 2002 - 02:33 PM
I typed in Killers method, and it works, really fast.
A little question, how can I get it to say "PA" behind the answer?
IanC wrote :
"PREASURE="
But if I typ it like that it wont work
Posted 14 December 2002 - 06:07 PM
It's very difficult to do this, because you can't
figure out the length of the output number (up to 14 Chars!) and
it's therefor impossible to set this text to the correct point!
Posted 14 December 2002 - 06:14 PM
Posted 14 December 2002 - 06:28 PM
ClrText
Locate 1,19,"PA"
Posted 14 December 2002 - 06:46 PM
The numbers can be up to 15 chars + 9 Chars for Pressure= is already 24 Chars! This will cut the length of the number to 9 Chars!!
I don't even recommend to use pressure as describtion! Better would be the
use of "pres.=" This would leave exactly the space needed to show all 15
chars! (And especially on numbers like 3,523534598E+10 the E+10 is very!!!
important)
Posted 14 December 2002 - 07:48 PM
Posted 15 December 2002 - 02:48 PM
Here are a few:
"abcde" are in Shift-F3-Stat-Graph or something, a few are in Optn-Esmn and there is also "rstp" in the same place as "abcde". Just look hard and you'll find them!
Posted 16 December 2002 - 10:28 AM
Posted 17 December 2002 - 08:29 AM
DO YOU KNOW HOW LAME THAT IS?!? This is what it would be like...
Milord, I've just RECIEVEd reports that our soldiers have LOCATEd an ORANGE dragon at the falls. IF it comes any closer it would EXEcute our villages. NOT again... the SIN of our people is being punished...
Posted 17 December 2002 - 04:28 PM
Posted 17 December 2002 - 05:57 PM
Next question, how can I, at the end of the program, make it go to TABLE, and use Y1 to Y5 and execute them?
