Hello,
I need that the result of a matrix multiplicacion can be affected by a modular function, for example, I will show a criptography exercise that use it:
(9 , 20 ) x
11 8
3 7 = (99 + 60, 72 + 140) = (159, 212)
thist result applying modulo 26 is = (3,4)
to this result, I need to applied a inversed matrix that multiplied with the computation above will give me the original number (9, 20), all using mod 26:
inverse
11 8
3 7 =
7 18
23 11
(3, 4) x
7 18
23 11 = (9, 20)
I need to do that with the classpad 300, somebody know do that?, thank you.
Amaury A.
Matrix Result Using Modular Arithmetic
aaracena
, Jul 31 2004 02:24 PM
Posted 31 July 2004 - 02:24 PM
Posted 31 July 2004 - 03:21 PM
you want to find the inverse or to apply the mod function ?
Posted 01 August 2004 - 04:29 PM
I need also to find the inverse, but bassically I need that the result of a matrix multiplication can be affected by a modular function, like I show in the example, thanks for you response.you want to find the inverse or to apply the mod function ?
Amaury A.
