Couple Of Questions
Posted 05 September 2004 - 12:01 AM
Posted 05 September 2004 - 10:13 AM
Posted 05 September 2004 - 01:47 PM
Posted 05 September 2004 - 02:22 PM
memzone library?This is caused by old programs misusing the memzone library or using bugged versions of it... :/
well i did had a bad file transfer...it happens to me occasionally, but not very often, it can be caused by a bad file transfer, but you get the error message at the end of the transfer.
'nother question, i have been playing Roe's f-16 game, and it requires a 16804 byte basic file be stored. and if my calc keeps getting reset, is there a way that i can send a file from the computer and tell it how big i want a file?
Posted 05 September 2004 - 02:32 PM
Posted 05 September 2004 - 05:30 PM
Some programs simply create invalid ones because they do not hear on
2072 and didn't update their version .
Bad file transfers never caused a memory error for me .. . yet
Posted 06 September 2004 - 12:37 AM
so is Touche better than LINL (or are they not even the same type of thing)? and does it come with the memzones library?you can use Touche or Gcomm to create a basic file of a special size.
Posted 06 September 2004 - 04:54 AM
ou can get the library at www.2072productions.com
Posted 06 September 2004 - 06:26 PM
btw, to reinerate my fisrt question, does anyone know where i can download the icons for CAS and ALGEBRA?
Posted 06 September 2004 - 07:20 PM
i downloaded Touche, but could find anywhere to create a basic file is the memzones library an addin too?
Launch Touche, choose memory zone info , press F3' />, then name the file - in this case SIMDATA. After that input desired size, and it's done
I hope it helps
Posted 06 September 2004 - 07:26 PM
Posted 06 September 2004 - 11:35 PM
Posted 07 September 2004 - 12:08 AM
Posted 07 September 2004 - 12:12 AM
Posted 07 September 2004 - 12:37 AM
Press F3, choos the file system, in the left side press ezport button, use a BMP editor cut CAS icons, and.... (you know it)
Posted 07 September 2004 - 12:59 AM
k, next question, what is the difference between CAS and ALGEBRA, they look excatly the same, and look like they do the same thing...
Posted 07 September 2004 - 01:04 AM
nevermind, i figured it out (i should have tried before i asked )
But I think it's the easiest way. (Fastest way too )
ALGEBRA application is same as CAS, but it let you to solve your problems step by step. For more info refer to manual of AFX
Posted 07 September 2004 - 01:12 AM
http://memphis.earth....com/menu1.mems
Posted 07 September 2004 - 02:04 AM
Posted 08 September 2004 - 02:50 AM
and another question, i downloaded GComm, but how do i compile it? and will it run in <{GNULINUX}>?
Posted 08 September 2004 - 01:21 PM
For your icons problem it means that some pages of the menu where not properly updated with the new icon... :/
Posted 08 September 2004 - 02:26 PM
options dialog of flash100
Posted 08 September 2004 - 05:54 PM
so i just send it to the calc? (how do i run it, or do i need too?)Gcomm is a program designed to run on the calc, you don't have to compile it. Then you use Gcomm to communicate with Flash100 with the Gcomm protocol
thanks, i will try that... you can set the behavoiour (take Items over to next menu) in the
Posted 08 September 2004 - 06:17 PM
either link it to the menu or execute it with an explorer (like the one built in TOUCHE or linl)
#25
Posted 09 September 2004 - 12:08 AM
where can i do that at?... you can set the behavoiour (take Items over to next menu) in the
#26
Posted 09 September 2004 - 04:35 AM
#27
Posted 09 September 2004 - 09:08 PM
oh, i downloaded the source code for it makes more sense now that i have the exe fileyou need to send the executable (gcomm.exe) over to the calc and
