DATA ERROR! 44 Read User's Guide Confirmed: [EXE] OFF : [ESC]the errors alternate between 44, 40, 64, and 60
when i push ESC' /> the calc turns off, when i push EXE' />, it says...
RESET (CLEAR) STORAGE MEMORIES? Yes: [EXE] No : [ESC]if i push ESC' /> it goes back to the first error, when i push EXE' /> it says...
CLEARING MEMORYthen it usually goes back to the error page and either repeats the same error, or gives a new one how do i fix this?
(btw, when i was doing this, it said "STORAGE MEMORIES CLEARED!" "PRESS MENU key to continue, and this seems to work, but it did the same thing earlier and now is having problems again, so i still am getting the same errors)
--edit--
nevermind, forget the "btw" comment, i am getting the errors again
