Delta-star Circuit
Posted 15 October 2004 - 04:46 AM
Text 15,20,A
also wanted to form it to work with complex numbers by I complete wanted to know if I can add an extra key for a function to the keyboard decimal.
if you can helpme with this after I can do anothers programas to solve some ac circuits
manuel franco
Posted 15 October 2004 - 05:36 AM
you can then use round(1.7689932882,2) to get 1.77
Posted 15 October 2004 - 09:40 PM
In spanish:
Acerca de los n?meros complejos, pon un ejemplo sencillo sobre que necesitas, para as? poder ayudarte. Podr?as bajar el archivo de la stdlib e instalarla, o simplemente ver el c?digo de esa funci?n y anexarlo a tu programa.
Posted 17 October 2004 - 07:44 AM
Posted 18 October 2004 - 03:09 AM
Buy an AFX, and use the program on my site.
thanks but I dont have money to do that
Posted 18 October 2004 - 03:46 AM
About the complex numbers, try to put a single example for us of what do you want, then we can help you better. You can try to download the stdlib or see the code of that function and use it
In spanish:
ok for example Z=[(1+i)(2+2.7i)+(5+5i)(-i)+(i)(-5i)]/i
and need a answer like -0.3-9.3i
Posted 18 October 2004 - 03:52 AM
thanks, that is a very good tipdownload the standard Basic Library (http://www.crimsonca....com/stdlib.php)
i going to try it
Posted 18 October 2004 - 07:49 PM
