The questions are :
1.- How can i draw, simultaneously 2 graphs in at the same time?
2.- How can i draw the sinusoidal curve that appears in the exercise?
Thaks a lot
George.
Posted 22 December 2004 - 07:26 PM
Posted 22 December 2004 - 10:58 PM
Posted 23 December 2004 - 12:28 PM
The example is from the upcoming OS 2.0, which has the spreadsheet built-in. I don't know if you can do this example using the add-in spreadsheet.
The built-in spreadsheet is an improved version. You can do a few things that you couldn't in the add-in.Also because it is built-in, you can put a spreadsheet in an eActivity, and I'm pretty sure you can drag-and-drop an equation from the eActivity to the spreadsheet graph. (I'm not positive if you can do this, but I'm pretty sure.)
I checked classpad.net, and it looks like OS 2.0 isn't availablw for download yet. I imagine it will be available VERY soon because there is already aneActivity using the built-in spreadsheet and OS 2.0.
Posted 24 December 2004 - 01:41 PM
Roger, Roger SoftCalc. we must be patient then.
Posted 26 December 2004 - 07:15 AM
However, why the Fourier example that i mention is posted thogether with the spreadsheet add-in version????. It is extrange
