Fx-95ms Help!
6 replies to this topic
#1 xhaohaox
xhaohaox
  • 3 posts
    fx-95ms
    Ti financial calc
Posted 23 February 2005 - 09:32 AM
hi, i am new here. does anyone know the special series of keys to press on the fx-95ms to get to the special mode or diagnostic mode? i remember having an old and cheap calculator which could do base after pressing shift, on and tangent at the same time and releasing the shift and on and press mode. it could even do complex numbers after going into that mode!!! it was a casio fx-911z
#2 Guest_Sergei Frolov_*
  • Guests
Posted 23 February 2005 - 09:56 AM
<span class=Shift' /> - [on]
#3 xhaohaox
xhaohaox
  • 3 posts
    fx-95ms
    Ti financial calc
Posted 25 February 2005 - 03:51 PM
erm, its for the fx-95ms rite? cuz i cant seem to get it to work. press shift then minus then on at the same time?
<{POST_SNAPBACK}>
#4 Guest_Sergei Frolov_*
  • Guests
Posted 25 February 2005 - 05:37 PM
No, just hold the <span class=Shift' />, then press and depress the [NO] key while <span class=Shift' /> is pressed.
#5 xhaohaox
xhaohaox
  • 3 posts
    fx-95ms
    Ti financial calc
Posted 26 February 2005 - 09:19 AM
nevermind. i dont think you know which model i am using becuz it still dosent work. press shift and hold then on right? well in just does not seem to work.i found out that 7-shift-on works but still cant get it to work with complex numbers conversions and base. I see all these icons on the screen. the Fx-911ms can. i think the Fx-911ms is the same as the Fx-95ms just that they disabled some functions in the firmware.
#6 Guest_lalala_*
Guest_lalala_*
  • Guests
Posted 25 October 2005 - 07:50 PM
how u convert complex numbers? i dunno how to press and wad is the base?
#7 Guest_Gautham Palaniappan_*
  • Guests
Posted 03 June 2007 - 12:21 PM
Its easy. Press SHIFT + 7 + ON. That gets you in the mode. Then press the shift key again and again. When it gets to 0 , press alpha. then to reset just press the power button.
Is this the one or are you talking about the other ssecret mode that you need to press tan and sin 1, 3 and all that?
