Please help me everyone. I need this calculator for school badly. My problem with the Casio FX-7000G is that any calculation I put in equals 0. For example, if I type in 9x9 it equals 0.
thanks
Serious Fx-7000g Problem. All Results Are 0
cozmicf
, Apr 12 2005 10:18 AM
Posted 12 April 2005 - 10:18 AM
Guest_Sergei Frolov_*
Posted 12 April 2005 - 11:01 AM
Try to use the Reset button at back side of calculator.
Posted 12 April 2005 - 07:25 PM
Or, if that doesn't work, there is a more cretive solution to this problem.
Step 1: Place the calculator on a flat, dry surface-face up
Step 2: Make sure that there are no particles on the face of it
Step 3: Check the time to make sure it is between 3:00pm and 7:00am
Step 4: Take a large hammer and hit the calculator until it gives you the right answer.
Disclaimer: I am not responsible for any damage caused by following these instructions
Maybe you should send it in before you go through all of this though...
