![Photo](https://secure.gravatar.com/avatar/81ed79adafe6f2ecd82475a77fee4ae6?s=100&d=https%3A%2F%2Fcommunity.casiocalc.org%2Fdot%2Fpublic%2Fstyle_images%2Fmaster%2Fprofile%2Fdefault_large.png)
Need Help With Program
Posted 03 May 2005 - 08:23 PM
Kind of new here and just wandered if I could get some help with a program I am making.
\Lbl 1
\Norm
\Cls
\Text 3,5,"XSOLVER.©.2005 BARNETV"
\Text 9,1,"--------------------------------"
\Green \Text 20,5,"TYPE EQUATION INTO GRAPH Y1"
\Text 35,5,"ARRANGE EQUATION SO THAT"
\Text 45,5,"ONE SIDE EQUALS ZERO"
\Green \Text 57,5,"NOTE: SOLVES ONLY ONE ANSWER"
\Do
\LpWhile \Getkey\<>31
\Cls
2\->B
\Solve(\Y 1,0)\->A
\Text 25,30,"X="
\Text 25,40,A\Disp\Goto1
%End
I have wrote the whole program but can't find the "Disp" button at the end, this makes the program bugging.
Posted 03 May 2005 - 08:34 PM
Posted 03 May 2005 - 10:05 PM
![<span class=](/dot/public/style_emoticons/default/SHIFT.jpg)
![<span class=](/dot/public/style_emoticons/default/VARS.jpg)
![<span class=](/dot/public/style_emoticons/default/F5.jpg)
Posted 04 May 2005 - 11:35 AM
Just can't understand why I get "Syn ERROR"
Any suggestion?
Also tried to make the game called PONG, but also there I got "Syn ERROR"
Please help me
![:D](/dot/public/style_emoticons/default/biggrin.png)
Posted 04 May 2005 - 01:09 PM
And please be sure to use the commands from the menus (e.g. Solve( ) and not to type them in.
Thx Huhn
Posted 04 May 2005 - 01:44 PM
tnx
![:)](/dot/public/style_emoticons/default/smile.png)
Posted 04 May 2005 - 04:49 PM
What calc do you have? If you have the old CFX9850G not the GB Plus: In the games I wrote on my old CFX 9850G (it's broken meanwhile, may it rest in peace) I noticed a bug when you try to evaluate the result returned by getkey directly (e.g. "if getkey = ..."). For the new GB Plus this works fine though.
I bypassed the problem by
Do Getkey->K LpWhile K <> 31
PS: If you mean the return symbol by "\", you must type "\LpWhile Getkey<>31" not "\LpWhile \Getkey\<>31". But I guess this isn't the problem else "\Green \Text 20,5,"TYPE EQUATION INTO GRAPH Y1"" would give an error already
PPS: Ensure you have a "Do" before the "LpWhile" (but in your first post you have it)
Posted 04 May 2005 - 07:33 PM
may be your problem, as i recall some models had problems using : in quotes, change it to:
\Green \Text 57,5,"NOTE- SOLVES ONLY ONE ANSWER"
and see if the problem goes away.
Posted 04 May 2005 - 11:24 PM
when the condition of the => is FALSE, the execution continues after the first 'return' or ':', even if it's inside quotes...
syn error : did you write <> of =/= (not-equals-symbol) ?
<>, or >< or != or =/= are txt representations of the not-equals-symbol, you must not type the two symbols < and >
marco : the \ in txts is just a symbol indicating the following atom is a "command" (i.e. you must type it from menus, not letter by letter) (and we see that <> is a "command" and not the two chars < and >)
Posted 05 May 2005 - 04:00 AM
I bet this Pong game he mentioned is mine too!!!!
![:angry:](/dot/public/style_emoticons/default/mad.gif)
This deserves a warning!
![<_<](/dot/public/style_emoticons/default/dry.png)
====EDIT====
Sorry about this post. Thanks for apologising.
I just dislike it when people claim programs as their own. I had a few bad experience when I was at school.
Posted 05 May 2005 - 08:48 AM
I didn't made the program but I still got problems with it.
I said some stupid things in the beginning of this topic, thats beacause I was so frustraded we I couldn't get the program running...
I didn't mean to steal your program, just try it out.
![:huh:](/dot/public/style_emoticons/default/huh.png)
By the way I still can't get the program working even after I changed <> to goto. What I haven't done is to use all the / in the program.
Posted 05 May 2005 - 09:07 AM
@barnetv: you should download FA123, is free for download, and it will allow you to see the code 'properly' without all the extra slashes and with the correct symbols
Posted 05 May 2005 - 09:10 AM
\Text 3,5,"XSOLVER.?.2005 BARNETV"
btw, i'm trying to think of what he typed wrong
@barnetv: dont include the / in the program. they shouldnt be there.By the way I still can't get the program working even after I changed <> to goto. What I haven't done is to use all the / in the program.
download FA123 here
http://www.casioed.n...ducts/fa123.htm
also, does your calculator have the Solver function? X-Solver does the same thing as Solver.
Posted 05 May 2005 - 09:37 AM
yeah, i forgive you barnetv. can you at least change his name in the first post to mine. thanks andy.
download FA123 here
Thanks
Yes my calc do have something called G-solv.
Just wanted to see what the program did.
Are there any places I can find progs for my math term next week?
Anything that solves "Power" I don't know exactly what it's called in english.
But number or letters that have a small number upside in right corner.
Or any program that solves cubes, circles or triangles in easy way. Also algorithm.
Cos, sin, tan and that stuff..
Thank you guys
Posted 05 May 2005 - 09:41 AM
visit here for more math programs.
http://charliewatson...io/casprog.html
you should consider buying/building a computer link cable as well.
For building visit: http://casiofortissimo.earthforge.com/
For buying visit: http://charliewatson...o/casorder.html
Posted 05 May 2005 - 10:04 AM
Posted 05 May 2005 - 10:11 AM
btw, i think your member title is wrong. is it meant to say Forum Ghost?
Posted 05 May 2005 - 05:14 PM
Now I have managed to make a lot of programs. Thank you guys
But I wandered if anyone of you got a program for "Probability" or "Trigonometry"?
Please let me know
Posted 05 May 2005 - 09:55 PM
What features do you need? For my final math exam in school two years ago I made a Casio CFX program called "MathMatX" (it helped me passing that exam very wellBut I wandered if anyone of you got a program for "Probability" or "Trigonometry"?
geometrie / trigonometry (location of point/even/plane to each other, vectors, circles, area and volumina, polygons, ...),
propability / stochastics (binominal distribution, conditional propability, PHI function, Tschebyscheff inequations)
prime numbers, LCM/GCD and polynominal divisions.
The only thing is that it's german version only, but I also started making an english version (though didn't finish it). Finishing it yet wouldn't be a problem for me as there are only few strings left to translate.
Posted 06 May 2005 - 01:17 AM
Posted 06 May 2005 - 10:06 AM
Now I have "Installed" the program called "TRIANGLE.CAT" on my calc. I worked fine, with no errors but I can't write numbers into any of the things on the left side.
BX:
CX:
A-:
It is just blinking 0. I can push EXE and then it jump to the next but I can't write in them
![:blink:](/dot/public/style_emoticons/default/blink.png)
Please help.. Looks like a great program
Posted 06 May 2005 - 10:21 AM
f1 = -0.1
f2 = +0.1
f3 = - 1
f4 = + 1
f5 = - 5
f6 = + 5
i think thats it anyway
Leave a number set to 0 to solve that value, and exe to confirm a value entered.
Posted 08 May 2005 - 10:17 AM
) providing much things:
Hi.
I have my math term at Tuesday, so I was hoping you could show me the program before that
Thanks
Posted 08 May 2005 - 01:19 PM
#26
Guest_Guest_*
Posted 11 May 2005 - 01:46 PM
#27
Posted 12 May 2005 - 12:37 PM
