![Photo](https://secure.gravatar.com/avatar/9c686de63492d46ee62a3331f71d4f56?s=100&d=https%3A%2F%2Fcommunity.casiocalc.org%2Fdot%2Fpublic%2Fstyle_images%2Fmaster%2Fprofile%2Fdefault_large.png)
Help Plz... Flash Ng (afx 2.0 Plus)
Posted 12 June 2005 - 12:39 AM
everytime i run my calculator it shows DATA ERROR with DIFFERENT NO every time
now its DATA ERROR 60 .... before DATA ERROR 4C
when i accessed the service menu.. and made a checkup.....
everything is OK
BUT THE FLASH IS NG...
my calc. is AFX. 2.0 PLUS
how can i repair it....
is it a software problem ? or hardware one ???
when i removed thebackup battery the calculator opened with no errors ...runs for mins...then errors apeared again...
any help will be appreciated
bye
Posted 12 June 2005 - 04:28 AM
Posted 12 June 2005 - 04:32 AM
Posted 12 June 2005 - 09:40 AM
me that it was a hardware problem. In fact the soldering of the
flash chip was no too good and so they had to do it again.
Since then the calc ran fine.
Just send it in if you have still guarantee. It is the best way. Do only try to solder it yourself if you know what you#re doing. You'll loose warranty and if you fail even the calc ...
Cu Huhn
Posted 12 June 2005 - 12:02 PM
the calculator by the way is out of warranty now
![:(](/dot/public/style_emoticons/default/sad.png)
so its useless now....id do anything to make it work!...or let it burn.....
by the way how do i intialize it ???
EDIT:
by the way how can i identify the FLASH CHIP IN THE CALCULATOR? Andy.Davies: Please dont post twice in a row in a short space of time |
Edited by Andy.Davies, 12 June 2005 - 01:43 PM.
Posted 12 June 2005 - 12:41 PM
Posted 12 June 2005 - 12:58 PM
![:)](/dot/public/style_emoticons/default/smile.png)
Posted 12 June 2005 - 04:03 PM
they just said the re-soldered some things and I assume that it was the flash.
if you want to initialize it you have to goe to the hidden test menu and do the "Whole Flash" Flash Test.
On next restart it shows an error (DATA ERROR 80 i believe) and then the flash will be initialized on pressing enter.
This is due to the fact that drive A (system) hast to be copied back from ROM for the calc to work.
Just try it
![:D](/dot/public/style_emoticons/default/biggrin.png)
Posted 12 June 2005 - 09:14 PM
Posted 14 June 2005 - 09:53 PM
Posted 03 July 2008 - 06:48 PM
Posted 03 July 2008 - 10:22 PM
Posted 04 July 2008 - 12:38 PM
In my region I bought a small "made in china" unit for $51 including the flux, its very handy and reliable.
http://www.gsmserver...ils.php?id=8519
mine is similar to the one in the link; but with one digital display.
Posted 08 July 2008 - 04:37 AM
Posted 08 July 2008 - 11:24 AM
I haven?t tried HP50g; maybe some one will give you an advice.
Regards.
Posted 08 July 2008 - 11:57 AM
Posted 22 July 2008 - 06:22 AM
Posted 24 July 2008 - 01:04 AM
Posted 24 July 2008 - 02:14 AM
Posted 27 July 2008 - 01:04 AM
