I DON`T RUN THE PROGRAM "CONST AND CONVR" I DON`T KNOW
AND SOMEDOBY KNOW WHERE CAN OBTEIND THIS PROGRAM
..... SOMEBODY KNOW IF THE CLASSPAD SOLVE ECUATION DIFERENT PARCIAL
GRACIAS
Posted 09 October 2005 - 09:18 PM
Posted 10 October 2005 - 01:08 AM
Posted 28 November 2005 - 01:01 PM
Posted 29 November 2005 - 01:30 PM
Posted 29 November 2005 - 07:30 PM
Posted 30 November 2005 - 07:45 PM
Yes I know it everything. Question is do I can use also string functions and manage equations, can put string as a argument? and give string as a value?
Local l1
{1,2,3,4}=>l1
Return l1[1]is not allowed Posted 02 December 2005 - 07:37 AM
Now, this is a real confession. I suspected that your Add-In simply changes the type of the file, I have posted something about it three months ago, when you argued that your Add-In works well, but you didn't answered. Finally, you say the truth, and it seems that I was completely right. Ok, you have never said that your Add-In does miracles, but you should explain how it works earlier...the only thing my program does is to change the type PRGM into FUNC! Yes and the file is not changed at all!
Posted 02 December 2005 - 05:44 PM
Posted 02 December 2005 - 06:57 PM
No you can't use string functions (excepted strToExp()), but you can give a string as an argument and return a string.
Posted 02 December 2005 - 07:12 PM
I want to be sure if I understood this well....
I can give a string as a argument and return... the same string???![]()
Am I right?
Posted 02 December 2005 - 07:14 PM
Yes
so CPBasic will be rotten forever.
Posted 04 December 2005 - 08:54 AM
Are you sure you really need CP Basic? It's very poor and very slow, compared to CPLua.Not good... it could be very useful for me
Posted 04 December 2005 - 10:16 AM
Posted 09 December 2005 - 08:24 PM
