I've Got The Cable. Now What? (help)
Posted 20 October 2005 - 01:26 AM
http://cgi.ebay.com/...bayphotohosting
an have recieved it. when i plug it into my calc (fx 1.0 plus) and try to send it something with the fa 123 software i get a communication error. i found that the com port it's on is 3.
any help?
Posted 20 October 2005 - 09:04 AM
make sure FA123 is set to the correct port
make sure FA123 is sending in FX/AFX mode, not CFX mode
Posted 21 October 2005 - 12:35 AM
Posted 25 October 2005 - 04:19 AM
i was reading that the cable has to be 25pin but the one i have is 9 pin do i need an adapter?
also
do i need a patch for the fa 123 software ?fxi to cat? to make it work with my cable
finally
if i use a different operating system (currently xp) will it help?
thanks
Posted 25 October 2005 - 05:22 PM
2) No. You do want to install cat files don't you? since you can't install fxi with the FA-123
3) Yes. Try Win2K ... XP sucks!
Posted 25 October 2005 - 07:53 PM
Posted 25 October 2005 - 07:58 PM
I say M$ did never make a better os (in the windows series) than 2K what does not mean that 2k is a good os but it is, IMO the best from M$.
Btw. my XP is up2date but my 2K works all fine with only SP4
Posted 25 October 2005 - 08:20 PM
I used to accuse Micro$oft too when my computer crashed but I realized that the most often it's a problem related to non M$ software pieces or bad hardware (bad RAM or miscellaneous bad firmwares)
Posted 25 October 2005 - 10:16 PM
it still doesn't work
also
finally
thanks
has to be 25 pin? all the circuit diagrms i have show clearly that it can be wired to 25pin or 9 pin connectors.
it works fine on all my machines (Server 2003, XP Pro SP2, XP Pro SP2, XP Home SP2
Posted 26 October 2005 - 04:33 AM
i'm trying the cable on a win 98 computer but im still having prob
if i hit send from the computer my calc immediatly says recieve error. does this means the com port is right b/c the calc tries to recieve something?
also on this comp the com port is 1 and i am using the casiocom and fa 123 software.
im begining to think its the cables problem b/c this website show a cord with one hump
http://pfranc.com/pclink/pcl9.htm
while the one i bought has two smaller ones
thanks for your help
this is really frustrating
Posted 26 October 2005 - 08:04 AM
Posted 26 October 2005 - 01:51 PM
I don't want to sound mean or anything but are you sure the comport works? have you ever had any device working on it (e.g. modem) or is it, maybe, turned off in the BIOS?
Just to make sure
Posted 27 October 2005 - 12:22 AM
i had a palm pilot that used that com port but just in case how would i turn on the com port
@Andy.Davies
i cant get either of your sites to load in firefox
StormBase.Net doesn't have any afx stuff
and CasioFortissimo says renewal pending
Posted 27 October 2005 - 04:36 AM
i feel like an idiot
Posted 27 October 2005 - 07:24 AM
good luck with the cable tho
Posted 27 October 2005 - 07:50 PM
For turning on the comport:
This is in the "chipset features" setup of the bios. There you can turn the serial, paralell, usb, firewire, ethernet ... controllers on (enabled) or off (disabled). I think nearly all modern bioses have this option.
Posted 27 October 2005 - 11:16 PM
Posted 28 October 2005 - 12:28 PM
Posted 29 October 2005 - 01:17 AM
1 my com port is on
2 my cable works w/ hyperterminal
3 casio installer is able to open com port
4 plug in then i hit recieve on calc
5 hit send on comp with correct in prog settings (AFX, com1,)
6 calc says recieve error when data is sent
how is it not working!?!?!
Posted 29 October 2005 - 09:02 AM
Posted 29 October 2005 - 01:40 PM
Posted 30 October 2005 - 01:21 AM
it made a click
doesn't work
the calc can recieve and send to other calcs so it seems like it should work
Posted 30 October 2005 - 06:10 AM
#25
Posted 30 October 2005 - 08:34 AM
1. What happens when you test the cable in Hyperterminal (results please
2. can you test the cable with aanother pc/friends calc?
#26
Posted 31 October 2005 - 03:19 PM
i'll try to give it to a friend today and hope for the best!!
#27
Posted 31 October 2005 - 06:17 PM
#28
Posted 01 November 2005 - 01:45 AM
#29
Posted 02 November 2005 - 12:21 AM
#30
Posted 02 November 2005 - 12:45 AM
#31
Posted 02 November 2005 - 08:54 AM
#32
Posted 03 November 2005 - 04:10 AM
#33
Posted 19 November 2005 - 09:03 PM
i've test with self-made and official cable. Both cables have passed test hyperterminal. Trassmision error is show with Algebra FX 2.0+ and fx-9750G.
i run WinXP SP2 and i think if would can be it.
(i'm spanish, sorry my english)
#34
Posted 20 November 2005 - 08:52 AM
Does calc to calc transfer (with the other cable) work?
#35
Posted 20 November 2005 - 10:06 AM
#36
Posted 20 November 2005 - 11:31 PM
