9860 Fa-124 Converting G1m To Cat To Fxi
19 replies to this topic
#1 caspro
caspro
  • 216 posts
Posted 30 October 2005 - 08:49 PM
EDIT:
This message originally gave long message about conversions.
That method can still be read in the tutorials forum.
Since this message was posted a couple of things happened to replace the method originally described:
1) Now available is a version of FA-124 with 9860<=>9850 conversion at:
http://www.casiokingdom.org/
For details see:
http://www.casiocalc...?showtopic=2726
2) Cat2fxi versions 2,3 have some bugs , which means fxi ->cat or g1m won't work.
cat -> fxi works well enough
but going the other way
fxi -> cat doesn't work
because cat2fxi v 2 or 3 don't translate fxi + and - symbols correctly
and puts newline symbols on every line even after display symbols.
I've written Casform: a g1m,txt,ctf,cat,fxi converter to replace cat2fxi.
http://www.spiderpix...formindex.html
#2 os008
os008
  • 32 posts
    FX-9860G
    FX-570ES
Posted 23 December 2005 - 06:50 AM
thanks for this guide, but how can i create a new program in the first place, in FX2.0 mode there's a "NEW" in "FILE" menu, but in the 9860G, there'sn't, which is odd!
EDIT:I have found out how to convert, thanks.
#3 huhn_m
huhn_m
  • 1957 posts
  • Interests:Assembler(!!!)
    Computers and Programming
    Operating Systems
    Programmable Calculators
    Maths and everything arround it
    FX-82SX / AFX 2.0+ (ROM 1.03) / FX 1.0+ (ROM 1.03)
Posted 23 December 2005 - 10:28 AM
Post has been added to tutorial section and reformated (some mistakes corrected)
Thanks caspro!
#4 os008
os008
  • 32 posts
    FX-9860G
    FX-570ES
Posted 23 December 2005 - 05:33 PM
here's a more simple way ...
1-Open FA-124
2-Choose "Tool" drop down menu
3-Choose Model ... Algebra FX
4-Open whatever CAT file u want
5-Choose "Tool" again, then choose "Convert" ... one of the 2 options should be available now, depending on the type of CAT file u have.
6-Now you should find the G1R file in "My Documents\CASIO\FA-124"
NOTE: when u upload the program to the calculator it will go to the Flash, it won't work from there, u have to go to the Memory Manager, then choose F2, then select the program with F1, then press F2 to copy it to the RAM, that's the most annoying thing i have ever seen, now the program should be in the Programs Menu. (Huhn, u could add this note anywhere u want for people to see, or leave it here if u want, thanks all for trying to help me before :)
#5 caspro
caspro
  • 216 posts
Posted 04 January 2006 - 03:03 PM
I certainly thought there should be a simpler method
and, upon reading your post, immediately went to check the software
but there is no 'Convert' option in the version FA-124
that I got from jeuxcasio.com.
(If anyone can see differently, then tell me.)
The different language versions of FA-124 seem to have different features.
huhn_m, perhaps you could add to the tutorial the fact that other
language versions of FA-124 have a simpler conversion method for cat->g1m
although the ctf and fxi information still stands.
#6 os008
os008
  • 32 posts
    FX-9860G
    FX-570ES
Posted 04 January 2006 - 11:40 PM
there's nothing more simple than that man, and open CAT files only, these r the only ones to be converted using my method ;)
#7 Guest_Harry Becher_*
  • Guests
Posted 11 March 2006 - 12:29 AM
I'm having the same problem. After I open the *.cat file using FX-124, there is nothing to convert it to a *.g1r file under tools. What should I do?
#8 caspro
caspro
  • 216 posts
Posted 11 March 2006 - 08:44 PM
There is now a version of FA-124 available online which does have the conversion feature:
For details see:
http://www.casiofx.tk/
#9 casiokingdom
casiokingdom
    UCF BASIC Programming 2nd Place
  • 782 posts
    CFX-9850GB PLUS WE, fx-9860G AU
Posted 12 March 2006 - 05:24 AM
if that link doesn't work. Use http://ck.earthforge.com
#10 huhn_m
huhn_m
  • 1957 posts
    Operating Systems
Posted 12 March 2006 - 10:54 AM
Earthforge is gone I think.
May it rest in peace.
#11 Andy.Davies
Andy.Davies
    Forum Ghost
  • 1547 posts
  • Interests:Age: 18
    Studying: MEng in cybernetics at Reading uni
    Interests: Progaming (VB, VB.Net, C#, Casio Basic)
    Computers UBBD (Using, Building, Breaking &amp; Destroying)
    Gaming (FPS, RTS, RPG)
    Electronics
    Rock Music (Preferably Loud)
    Riley's (Pool &amp; Snooker Bar)
    Driving (Preferably fast)
    Aikedo (Martial Art)
    Algebra FX 2.0 ROM 1.01, FX9750G
Posted 12 March 2006 - 12:09 PM
earthforge still loads for me...
#12 huhn_m
huhn_m
  • 1957 posts
    Operating Systems
Posted 12 March 2006 - 03:31 PM
well, so it still seems to be caused by my provider ...
though root12.co.uk does work now (opposed to before I complained) ...
I HATE strato!
#13 caspro
caspro
  • 216 posts
Posted 16 May 2006 - 08:24 PM
A quicker method to convert fxi or ctf or txt to g1m than the above is now:
Casform (version 6): g1m,txt,ctf,cat,fxi converter
http://www.spiderpix...sformindex.html
#14 caspro
caspro
  • 216 posts
Posted 22 May 2006 - 10:38 AM
I never got any problems with converting .g1m to .cat or .fxi
...since I'm the proud owner of a fx-9860G SD and CFX-9850GC PLUS! :D
Question:
Does the 9860 have the old serial port.
If so, do you know whether FX-Interface and Xchange work with the 9860 ?
However, most people will be thanking you for that converter. ;)
Actually, I've found so many bugs since I posted that message,
that I don't think anyone would have found it much use.
So ...
Version 8:
#15 Guest_Billy R. Adams_*
  • Guests
Posted 04 August 2007 - 08:20 PM
#16 Guest_Billy R. Adams_*
  • Guests
Posted 04 August 2007 - 08:36 PM
Probably to old question, but :
On the program-link CASIO FA-124 Computer window for the fx-9860 series calculator:
To open a new program:
1. In the right Computer window, highlight the Program icon (or any program name under it).
2. In the top CASIO FA-124 Computer window, Left Click the Item button.
3. Options are: "New" & "Open". Click New. Enter: new File Name. Click "OK"
4. Now click on the newly created progream icon to edit it.
Billy
#17 Guest_T. Asinari_*
Guest_T. Asinari_*
  • Guests
Posted 08 June 2010 - 05:27 AM
Hey I am trying 2 install FA-124 on my comp.
However when I run the install I always get:"The Wizard was interrupted before CASIO FA-124 coould be completely installed. You system has not been modified. To complete installation at another time please run set up again."
Its not clear what's interrupting the wizard. Tho I suspected that maybe my files with eActivity ad-ins and calc manuals maybe interfering w/ the directory. If anybody has any ideas or has seen this before please tell me. I bought FX-9860 GII recently and I wanted to install physium on it.
ty
T. Asinari
(my apologies if this is not the right forum to mention this)
#18 HabanR
HabanR
  • 32 posts
Posted 08 June 2010 - 08:28 AM
ty
T. Asinari
What operating system do you use. Casio doesn't support 64bit OS
#19 Guest_T. Asinari_*
Guest_T. Asinari_*
  • Guests
Posted 08 June 2010 - 09:58 PM
That explains everything OS is 64 bit Vista Home Premium.
Is there any way around this?
ty
T. Asinari
#20 peter
peter
  • 8 posts
    cfx 9850gb+ [32kb] cfx 9850gb+WE [64kb]
    fx82au
Posted 05 August 2022 - 05:02 AM
i have found it at this site   https://engineerings...Casio_Utilities
