1) Do we need comments?
2) Do we need variable spacing (e.g. should the compiler watch for and remove tailing, leading, additional spaces)?
3) Give me one reason why we would need an extra variable type for colors
4) Would you like the compiler to output byteode (e.g. to distribute it)? This would decrease load times and make the transmitted programs smaller by a factor of up to 5 (estimation!).
5) Do you want a Live Interface (LI) that, when the calc is connected to a computer with internet access and LI software, would make it possible to search the web for programs in a common repository and download them automatically to the calc?
6) Who is willing to write this *$"$!& editor?
7) Do you want MLC2 to become a CVS / Community Project after th first full version release? If yes, would you have the time and will to help getting it to the next level?
8) What is more important: Verbose Error output by the compiler or size and speed optimization? (This only affects the compiler! The interpreter will ALWAYS be optimized for speed since it can only catch verry few errors.)
9) Do you want a wiki for documentation (I don't have the time to write it but I could put it on my new server and set it up. You only need to write it). If yes, would you help write it?
10) Will you download the Beta even it is, in its current state useless for actuall development?
11) Do you have the need for a PC Compiler and Interpreter?
12) If yes, would you write one? I would give you all the needed specs!
I hope many of you will anwser these questions! This project relies on your help. (At least I would like to get some encouragement from time to time
