Afx 2.0 + / Fx 1.0+ Tutorials
#1 huhn_m
huhn_m
  • 1957 posts
  • Interests:Assembler(!!!)
    Computers and Programming
    Operating Systems
    Programmable Calculators
    Maths and everything arround it
    FX-82SX / AFX 2.0+ (ROM 1.03) / FX 1.0+ (ROM 1.03)
Posted 29 March 2006 - 04:56 PM
Converting the FX 1.0+ (ROM 1.03) to AFX
Enabling CAS ALGEBRA and TUTOR – English version
For the FX 1.0 Plus ( ROM 1.03 )
1 – Get the FlashCOM 1.5 ( in the File Sharing or in any CASIO dedicated web page ).
2 – Run it
3 – Connect your calculator whit the PC ( using the link cable ).
4 – In FlashCOM, in “COM Number” set the number of your Com port *.
5 – Select “System”, and click on “Receive”
6 - Select the folder and file name and save the system file in your had disk.
* If you don’t know the COM number, just put numbers from 1 to 9 and click on “Receive” until it works.
7 - Now click on “Open System”, and then click in “Number” until it reaches the same number show at “Total”.
8 – Click FIRST in “Total” to increase the number one time only then click in “Number” to increase it one time.
9 – In “Bitmap” click at the white square ( in the right side), and select CAS icon ( it will be more easier if the file name is CAS.BMP ), after that you can see the selected icon in the white square, then write the icon name in the white rectangle above the “Bitmap” ( for example CAS.BMP ).
10 - In “Name” write JOINT2.EXE, then in “Drive” write F:\, Now finally in “Arguments” write CAS, there is no need to put something in the “Version”.
11 – Now increase the number again first in “Total” and then in “Number”
12 – Repeat the Steps 9, 10 and 11 to add the Algebra and Tutor, the ONLY THING THAT YOU WILL CHANGE IS THE “Argument” ( ALGEBRA for the algebra program, and TUTOR for the tutorial program ), the icon and the respective icon name ( for example ALGEBRA.BMP and TUTOR.BMP ).
13 – Whit those 3 new icons, click in “Save System”, select the directory and file name, and finally save the new system file.
14 – Click in “Send” ( ATTENTION make sure that ONLY the “System” is selected ), Select the changed file system, then wait for the transfer ends.
15 – If everything works fine you are now a owner of a “cracked” FX1.0 Plus ;)
#2 huhn_m
huhn_m
  • 1957 posts
    Operating Systems
Posted 29 March 2006 - 06:05 PM
Converting the FX 1.0+ (ROM 1.02) to AFX
For the FX 1.0 ( ROM 1.02 )
1 ? Get the FlashCOM 1.5 ( in the File Sharing or in any CASIO dedicated web page ).
2 ? Run it
3 ? Connect your calculator whit the PC ( using the link cable ).
4 ? In FlashCOM, in ?COM Number? set the number of your Com port *.
5 ? Select ?System?, and click on ?Receive?
* If you don?t know the COM number, just put numbers from 1 to 9 and click on ?Receive? until it works.
7 - Now click on ?Open System?, and then click in ?Number? until it reaches the same number show at ?Total?.
8 ? Click FIRST in ?Total? to increase the number one time only then click in ?Number? to increase it one time.
9 ? In ?Bitmap? click at the white square ( in the right side), and select CAS icon ( it will be more easier if the file name is CAS.BMP ), after that you can see the selected icon in the white square, then write the icon name in the white rectangle above the ?Bitmap? ( for example CAS.BMP ).
10 - In ?Name? write CAS.EXE, then in ?Drive? write D:\, there is no need to put something in the ?Version? and ?Arguments?.
11 ? Now increase the number again first in ?Total? and then in ?Number?
12 ? Repeat the Steps 9, 10 and 11 to add the Algebra and Tutor, the ONLY THING THAT YOU WILL CHANGE IS THE ?Name? ( ALGEBRA.EXE for the algebra program, and TUTOR.EXE for the tutorial program ), the icon and the respective icon name ( for example ALGEBRA.BMP and TUTOR.BMP ).
13 ? Whit those 3 new icons, click in ?Save System?, select the directory and file name, and finally save the new system file.
14 ? Click in ?Send? ( ATTENTION make sure that ONLY the ?System? is selected ), Select the changed file system, then wait for the transfer ends.
15 ? If everything works fine you are now a owner of a ?cracked? FX1.0
