Str Function ...
Posted 21 May 2006 - 12:45 PM
is there anyway to use these functions and convert program to function or not?
Posted 25 May 2006 - 08:15 AM
In short: NO. There is an AddIn that "converts" a program to a function, but it simply changes the header of the file; it doesn't work as expected, and it has strong limitations. This is because function support in CP Basic is extremely limited (I can say, "primitive").one of the problems to convert a program to function is use of string functions...
My personal opinion is that, if you need real functions (supporting recursion etc), you should switch to CPLua, and forget CP Basic once and for all.
Posted 27 May 2006 - 04:21 AM
but the important think is to use funcyions in main calculator screenIn short: NO. There is an AddIn that "converts" a program to a function, but it simply changes the header of the file; it doesn't work as expected, and it has strong limitations. This is because function support in CP Basic is extremely limited (I can say, "primitive").
Posted 27 May 2006 - 03:49 PM
As far as I know, and I don't thik I'm wrong, you can only use CPBasic functions from the "Main" application, which means that you have very limited function support. I can say that you don't have function support at all - structures of one (and only one) statement cannot be called "functions". Inversely, though, you can use CAS statements within CPLua. Compared to a tru PC CAS, this approach is not without disadvantages, but you will have true function and CAS support.but the important think is to use funcyions in main calculator screen
