Fx-9860g - Add-ins Problem
#1 ndzamana
ndzamana
  • 13 posts
    ClassPad 300, fx-9860G SD, Algebra FX 2.0 Plus, CFX-9850G PLUS
Posted 17 June 2006 - 10:38 AM
Hello!
I have some problem with installing all add-ins in my fx-9860G. I copy it to caltulator memory but they doesn't work. :( E - con2 crash system, Physium cause error
"System ERROR
Press:EXIT
TLB ERROR!!
TARGET=00000200
PC =00303F94"
and icon for geometry turn on Recursion instead Geometry. I have try to instal this addins also form other computer and after RESET and "Initialize All" but everything is the same! I have also a problem to instal new system version "You calculator is a model that is not supported"??? :blink:
Is there some way to solve this problem?
#2 ndzamana
ndzamana
  • 13 posts
Posted 22 June 2006 - 05:52 PM
Yes! There is a problemem with calculator. As I found out I have test version of calculator (it has OS 00.26.0010) and it is impossible to install new OS and addin on this calc! So the problem is solved!
