Cfx-9850gb Plus Getkey Function Values
#1 Konfl1kt
Konfl1kt
    Casio CFX-9850GB PLUS
Posted 18 June 2006 - 02:32 AM
Im attempting to write a program that begins with a menu with each option being numbered. When you press the number corresponding to the option it takes you to that particular option. I've been using the Getkey function to do this, but I am unsure of the numeric value of the numbers I need.
For example to go to option 1 I used the following code:
Do
Getkey=72=>Goto 1
As the value of the number 1 on the keypad is 72.
Is there a site that lists all the values of keys in terms of the Getkey function or even a simple method of determining the value of the key?
Thanks
Konfl1kt
#2 casiokingdom
casiokingdom
    UCF BASIC Programming 2nd Place
  • 782 posts
    CFX-9850GB PLUS WE, fx-9860G AU
Posted 18 June 2006 - 05:25 AM
The getkey values should be in your manual.
Or
Create a new program:
Lbl 1
ClrText
Getkey
Locate 1,1,Ans
Goto 1
It will show you your getkey values
#3 R00KIE
R00KIE
  • 155 posts
  • Interests:Electronics, games, programming
    HP49G ROM 1.24; CASIO CFX-9850GB PLUS;CASIO FX-6300G; CASIO FX-82TL
Posted 20 June 2006 - 05:13 PM
Also a little tip don't do:
Getkey=70=>Goto 1
Getkey=71=>Goto 2
This will work but it may do things you aren't expecting, do this instead:
Getkey->K
K=70=>Goto 1
K=71=>Goto 2
