I just hope some Casio people will read me and...
1-First, a minor bug.
In STAT mode, if you press
Try typing "Dim List 1" and you will understand what I mean.
2- From an other post : I wish we could have complex matrixes and bigger ones.
3- Though "Sum List 1" gives a real for answer, you can't use it in a formula in Graph mode. You can write it using
Not to mention Mean or other list functions.
Too bad, I wish I could Graph some formulas like Y=sum((List 1-X)?)
4- In Stat Mode, the Graph called "MeanBox" doesn't exist any more (It exists in CFX 9850 for example).
Not that I use it often, but why supressing a feature ?
5- To graph functions such as
y=x? if x<2
y=x? if x>=2
I use this kind of formula (I recommend the trick, by the way) :
y=(X?)?(X<2)+(X?)?(X>=2)
However, the relational operators (<, >, etc.) can't be accessed other way than with the
I wish for an easier access in Graph formulas...
Any other whish ? Any workaround ?
EDIT :
6- No access to Function memory in Run mode when set up on Math Input Mode. Being able to recall a function anytime, edit it (by pressing "See" on the function memory menu) anytime would be wonderful
