hello
i really in need of your help...
my algebra fx 2.0 hangs every time
it stops working and i cant calculate and do my job .
how can i fix it?
Trouble With Algebra Fx 2.0 (help Me)
Mr.Mehdad
, Oct 13 2006 11:16 AM
Posted 13 October 2006 - 11:16 AM
Posted 13 October 2006 - 01:19 PM
Hello Mr.Mehdad! Welcome to the forum!
Maybe you need to update your OS or get a new calc. Could you please further explain your problem? Such as what are you trying to do on your calculator when it crashes?
Posted 13 October 2006 - 02:17 PM
hi, i think you must go to your casio retailer.....maybe they could help you....
or try this:
1) push reset button on calc back or....
2) try pressing a/b/c F6 and ac/on keys all at the same time (when your calc is off )
then a test menu appears, choose option reset, then reset all memories...or
3) in the same menu try the testing rom, ram, flash.
if you have still having problems, ask to 2072 or marko (or other forum administrators).....
have a nice day
protoman no one
or try this:
have a nice day
protoman no one
Posted 13 October 2006 - 02:48 PM
You could also try taking the batteries out, putting them back in again
and then press reset button.
Posted 13 October 2006 - 09:43 PM
Removing the baterries is worth a try if resetting memories doesn't help. But don't forget to remove the backup battery as well, and leave the calc without baterries for some time (half an hour maybe)...
Posted 17 December 2006 - 07:31 PM
hi
i do all of the work that you said. but my problem not solve
i guess the Flash Memory was damaged.
please Help to download a new flash
help help
help help
