![Photo](https://secure.gravatar.com/avatar/fa9ec8b5d7ea80a24389c1252395b25c?s=100&d=https%3A%2F%2Fcommunity.casiocalc.org%2Fdot%2Fpublic%2Fstyle_images%2Fmaster%2Fprofile%2Fdefault_large.png)
File Sharing Problem
Posted 29 October 2006 - 02:43 AM
i downloaded the all casio rar but i cant open the documents it says "this file is invalid for use as the following: Security Catalog" thanks for for help.
Vincent
Posted 29 October 2006 - 04:04 AM
Posted 29 October 2006 - 12:43 PM
Posted 13 June 2011 - 11:25 PM
how can i do woud i do it with copy and past its codes ?
please ,can you convert it to standard format i directly install them?
nyquist[/url] 29 2006, 01:43 PM' post='37389']
thx i just had to extract them and then i could open them with the fa-123. thx. will the fa-123 work with the FX 1.0 or do i need to download another program? thx for any help.
Posted 14 June 2011 - 03:17 AM
tool>model type>algebra fx series
then open the .cat file
then: tool>convert>fx9860 series/fx9750GII/fx7400GII
make sure you have the latest version of fa-124 instal-led.
also:
THIS IS BUNNY:
http://www.stumbleup...thisisbunny.com
(\__/)
(")_(")
Edited by mfischer, 14 June 2011 - 03:21 AM.
Posted 14 June 2011 - 03:29 AM
can i do it this way u say?i think it also need a csv file???!!!
open fa-124.
also:
THIS IS BUNNY:
(\__/)
(")_(")
Edited by javsalo, 14 June 2011 - 03:31 AM.
Posted 14 June 2011 - 01:46 PM
