Speed Comparison
Posted 30 December 2006 - 04:50 PM
Posted 25 January 2007 - 03:08 PM
Posted 25 January 2007 - 03:57 PM
1000->X Lbl 0 Dsz X Goto 0
The FX-9860GSD takes ~0.4 sec only, that is 9 times faster. But IMO this test is not convincing enough for a benchmark.
My overall impression of the FX-9860GSD: a real improvement to the predecessor calcs.
Posted 25 January 2007 - 04:08 PM
Guest_Mitiay_*
Posted 12 February 2007 - 02:38 PM
What hardware changes does it require?
Posted 12 February 2007 - 09:56 PM
It depends on the calculators hardware. There are 2 possibilities:
-changing the ceramic resonator or quartz, e.g. FX-603P.
-changing a resistor or capacitor, e.g. FX-602P.
If you have tested the benchmark on a calculator you cannot find in the list, more results are welcome.
Guest_Sergei Frolov_*
Posted 13 February 2007 - 05:23 AM
Where sines, logarithms, other complex functions and also floating point arithmetic when calculator operate with full-length mantissa?
Guest_Guest_*
Posted 13 February 2007 - 01:20 PM
I have tested my fx-7300G with your fx-7000G program: 71.0 seconds exactly
Posted 13 February 2007 - 01:45 PM
For 1->Z To 1850
Next
It made through this in one second, so I got a nice working timer.
Posted 13 February 2007 - 04:36 PM
This test is for non mathematical problems, like tools, games and etc. to see the differences of the calculators and languages.
I have also thought about a mathematical benchmark, but it is difficult to find a accurate way for comparing, however I'm working on it.
@Guest:
Thanks for testing. I have updated the table with your calculator.
@Crazio:
The FX-9860G is a very fast calculator in comparison. In the table it's the fastest calculator not using integers, so the intention to speed it up is not so great. But don't forget, there are many examples that your calculator cannot be fast enough.
Guest_Mitiay_*
Posted 16 February 2007 - 09:41 PM
FX-602P 466 seconds
fx-4800P 124 seconds
fx-6300G 141 seconds
fx-6500G 129 seconds
fx-7400G 125 seconds
Both Sharp EL-5120 and Citizen SRP-350 don't support arrays of any kind. In fact, it is possible to program a 8-Queens problem on these calculators, but formulas like Int(10Frac(A/10^X)) instead of A will lead to a very slow execution.
Posted 18 February 2007 - 12:13 AM
Interesting is the FX-602P compared to FX-603P. It's a pity to not have a FX-502P in the list now.
I like the FX-5800P, but the speed is a bit disappointing, if I look at the result of the FX-4800P.
I agree that the formula method of array handling to test the Sharp is much to slow.
Guest_Guest_*
Posted 18 February 2007 - 01:12 PM
Guest_Mitiay_*
Posted 18 February 2007 - 08:25 PM
FX-602P 465 seconds
fx-4800P 121 seconds
fx-6300G 135 seconds
fx-6500G 121 seconds
Posted 18 February 2007 - 10:00 PM
The speed of FX-7300P is really outstanding in comparison to the other 8-bit calculators. I guess the AFX is slower too.
@Mitiay:
The FX-602P can be speeded up to factor 3 by changing a resistor. The FX-602P turbo is as fast as the FX-603P.
Guest_Mitiay_*
Posted 07 March 2007 - 08:16 PM
First of all, instead of executong a Dsz{Letter}[{Expression}] command, this calculator allways does Isz{Letter}[{Expression}]. This bug doesn't affect simple Dsz{Letter} command (or at least I haven't noticed it
Mcl
8->R
Lbl 0
X=R=>Goto 4
Isz X
-R->A
Lbl 1
Isz S
X->Y
Lbl 2
Dsz Y
Deg
Y=0=>Goto 0
A -A[Y]->T
T=0=>Goto 3
X-Y<>Abs T=>Goto 2
Lbl3
Isz A (or Dsz A - it does the same thing
Goto 1
Dsz X
Goto 3
Lbl 4
S
Execution time is 148.5 seconds. ROM checksum of my calculator is 014A621A.
Posted 07 March 2007 - 10:34 PM
If you have noticed, a structured version is now available for testing languages without goto or if faster, but only the FX-9860G ist faster now. I have tested the FX-5800P (264 vs 227 sec) and TI-85 (150 vs 113 sec) also, but as you can see both are slower. May be the TI-89 or TI-V200 are faster.
Posted 18 March 2007 - 11:42 AM
Posted 18 March 2007 - 01:18 PM
I see there is no HP-41C in your list, only a HP-41CV and a HP41CX, I (or my dad) own a HP-41C but i can't take over the HP-41CV program, I don't know what y<>x means, and I can't find some command's. Is there somone who can help me whit this?
y<>x means y is not equal to x like y!=x
Posted 18 March 2007 - 01:20 PM
Posted 19 March 2007 - 11:35 AM
XEQ ALPHA 6 SHIFT SIN multiply 3 ALPHA
gives X<>Y?
If you want to test the speed, run the program by pressing
XEQ ALPHA SIGMA+ ALPHA
for about 10 seconds and then interrupt the execution by pressing R/S.
Now start executing again for measurement.
Posted 19 March 2007 - 04:10 PM
Why?
Posted 19 March 2007 - 04:30 PM
Posted 19 March 2007 - 04:41 PM
means execute program at label A.
Why start again? You can edit the program.
#25
Posted 19 March 2007 - 04:45 PM
SIGMA+ doesn't work.
#26
Posted 19 March 2007 - 04:55 PM
SHIFT EEX R/S
If your German is better than English:
Mit SIGMA+ ist nat?rlich nicht die Funktion, sondern das darunter stehende A gemeint. Also nach dr?cken von ALPHA erscheint ein A im Display wenn du SIGMA+ dr?ckst. Falls du nicht weiter kommst, kannst du mich auch in Deutsch fragen oder anmailen.
#27
Posted 30 March 2007 - 10:27 PM
The first Basic programmable calculator from Casio the FX-702P (1981).
The first programmable LCD calculator from Casio the FX-502P (1979). I guess the FX-502P is the fastest calculator of its time for this benchmark. Well done Casio.
#28
Posted 09 April 2007 - 12:26 PM
EDIT: Okay, changed how it handles results (approximate -> auto) and the time went down to 108 seconds.
EDIT2: Damn! Can't get the FX-9860GSD program to work on my CFX-9850GB Plus. I get a syntax error at the IfEnd and I can't seem to find anything wrong with the program. What's going on?
#29
Posted 09 April 2007 - 09:47 PM
#30
Posted 10 April 2007 - 06:44 PM
#31
Posted 10 April 2007 - 06:48 PM
#32
Posted 10 April 2007 - 07:25 PM
I looked at the program too, but I cannot find a bug. May be the program itself is not the problem but the Casio-Basic interpreter causes the problem. I will check it and post the solution.
@eew:
Can you explain the problem on the FX-9860G? If you check the program length, it has to be 196 bytes. One reason may be the unequal sign represented by "<>" in the code, but in the program editor its a combination of "/" and "=" not representable in ASCII.
#33
Posted 10 April 2007 - 07:27 PM
#34
Posted 10 April 2007 - 07:31 PM
Mat A[X,1]-1->Mat A[X,1]
WhileEnd
IfEnd
WhileEnd
LpWhile Y<>1
If you remove the first WhileEnd, it'll run fine, but the last three results will be negative, which I guess isn't right...
#35
Posted 10 April 2007 - 08:45 PM
#36
Posted 10 April 2007 - 09:40 PM
#37
Posted 10 April 2007 - 09:59 PM
Thanks for clarification. This is a really big bug, that dosn't allow structured programming without complications.
I guess the FX-9860G has different ROM-Versions, because the benchmark is executable on my FX-9860GSD.
#38
Posted 11 April 2007 - 09:24 PM
#39
Posted 11 April 2007 - 10:17 PM
Anyway, it took quite a few seconds, but it eventually returned 876. Also, Mat A=[[8,4,1,3,6,2,7,5]]... is that right? :3
EDIT: Nevermind, it is
#40
Posted 11 April 2007 - 10:21 PM
Well, I took the liberty of rewriting the FX-9860G BASIC program to something that will run correctly on the CFX-9850GB+. It required just a few small changes (I've put them in bold). This program will run slightly slower than what the original program would, due to an extra If clause. Shouldn't affect the times much, though. There might be a smarter way to rewrite the program, but this is what I came up with after a quick check.Good to know. In this case I will test the CFX-9850GB+ with the unstructured version to avoid this problem.
The time needed for a CFX-9850GB+ to execute this program is 141 seconds. That's actually not that slow. For comparison, the TI-89 made it in 108s, which is less of a difference than one might expect. Then again, the TI graphs between two and five times faster (at higher resolution), so this test is probably more of a BASIC interpreter test than a hardware test.
The modified program:
0->A~Z
8->R
Do
Isz X
R->Mat A[X,1]
Do
Isz S
X->Y
If Y>1
Then Do (*These two rows replace the original While Y>1.*)
Dsz Y
Mat A[X,1]-Mat A[Y,1]->T
If T=0 Or X-Y=Abs T
Then 0->Y
While Mat A[X,1]=0
Dsz X
WhileEnd
IfEnd
LpWhile Y>1
IfEnd (*These two rows replace the original WhileEnd.*)
LpWhile Y<>1
LpWhile X<>R
S
