Fx 9860g Au Help!
28 replies to this topic
#1 k1cks
k1cks
  • 3 posts
Posted 09 February 2007 - 05:38 AM
Not sure if this is where I ask but I cant seem to connect my pc and my calculator..
I have installed the FA-124 on disc like it says.. and completed these steps by ox...
1. go into FA-124, make sure that the calculator icon is selected (not the green pen and pad)
2. Go File > Open, and select and open the file
3. Under the computer sub window, a name of the file will appear, Ignore it for now
4. Turn on your calculator, go to the main menu, press D to enter link mode, then press F4(CABL), and F1 to select USB
5. Connect calculator to PC, and on the calculator press F2 to recieve
6. On the PC press the icon that looks like a calculator conected to a computor screen, and a loading bar will appear
7. When it is finished click and drag (don't open it) the file name i mentioned under the 3rd point of this tutorial
8. Drag it anywhere onto the words in the calculaor subwindow, and a transfer bar may appear
9. Click the icon that looks like a calculator conected to a computer screen again to disconect the calculator.
10. Remove the cable
11. On the calculator you will see a message saying transfer complete, press exit
12. Go in to the programs menu, highlight the program you want to start, press EXE, to start it.
13. if there is an error in the program, or if you press AC/on there will be a break or error message,
14. you will see lots of text, press EXIT, as if you change anything on this text (unless you know what you are doing) you will almost certainly ruin your program.
And when I open up FA-124 around steps 5 or 6 I get this error.
http://img19.imagesh...asiohelpui6.png
Can someone with higher knowledge please point me in the right direction?
Cheers,
Jacob
#2 Menno
Menno
  • 184 posts
    Casio 880P
    Casio Graph 25+
    Casio fx-9860g sd
Posted 09 February 2007 - 05:50 AM
I guess you missed point 6, it is the most left button, looks like a calculator. When the calc connects to the pc you will see files being read. after that the text"no calculator connected will be replaced with the name of the calulator and some subdirectory's
if the calc won't connect there is something wrong with your usb drivers. Or the 3-pin cable is selected in the connect screen of the calc, check this.
so in short:
connect the calc to pc (fysicly)
the calc will go into transfer mode automaticly when USB has been selected in the connect screen on the calc. when it is not connecting check if the usb cable is selected in the calculator.
Hit the button on the left that looks like your calc.
#3 k1cks
k1cks
  • 3 posts
Posted 09 February 2007 - 06:06 AM
Sorry I don't really understand what you are saying.
Is there any step by step picture guide you/someone could show me in order to do it in the right order.
Thanks =]
#4 CalcFan
CalcFan
  • 4 posts
    TI 85, TI 89, TI 92
    HP 28S, HP 49G+
    CASIO Classpad 300 Plus
    CASIO fx-7400 Gplus
    CASIO fx-9860G SD
    and other lesser beasts!
Posted 09 February 2007 - 10:53 AM
I get the "No more open files" message sometimes too. Unplugging the USB cable is all that is required to get it all going. I think it's just that the USB connection is not being recognised by the PC. I often see a similar lack of communication with media players and other USB media devices. Try temporarily disconnecting and then reconnecting the USB cable at either the PC or 9860 end. When you reconnect you should see the calculator switch on (if it was off previously of course) and then it should display the comms screen. You may have an error displayed on the 9860 from previous failures so clear that first (although I think it's cleared when you reconnect the USB cable anyway). FA-124 should then display a box showing what is being read from the 9860. If nothing happens then you need to go to the LINK screen and check the settings:
Cable type: USB
Wakeup: On
Capture: Memory (not sure if this is important)
HTH
#5 caspro
caspro
  • 216 posts
Posted 09 February 2007 - 12:49 PM
I found that the only way I could get the calculator to send programs to the computer
was to put the calculator in receive mode and then press the button in FA-124 which has an icon
of a calc connected to a pc.
Then I went into the right-hand window and then click on + to expand Default and then expanded + Program.
But FA-124 doesn't seem to work every time.
#6 purplemonkey
purplemonkey
  • 13 posts
    casio fx-9860G AU
Posted 11 February 2007 - 07:33 AM
is there any reason why my calc will connect with some computers and not others? on one computer it all works fine, but in another it says "no more open file" :profanity: , n i have tried everything ppl have suggested! :( plz dnt say use the one it works with, coz i would but that computer does not currently have internet so i cant do much. any info would be a BIG help!!!
#7 casiokingdom
casiokingdom
    UCF BASIC Programming 2nd Place
  • 782 posts
    CFX-9850GB PLUS WE, fx-9860G AU
Posted 11 February 2007 - 01:48 PM
Are you connecting it through a hub?
According to a member on my site:
don't run the calculator though a usb hub.
if you run it through a usb hub, windows will recognise that the calculator is plugged in (and it will say its name) (this is bad because Microsoft doesn't support the casio drivers).
#8 purplemonkey
purplemonkey
  • 13 posts
    casio fx-9860G AU
Posted 12 February 2007 - 05:42 AM
um, no, i dont think i am.....? :unsure: the only difference betwen the computers is that with one, the usb cable goes straight from the computer to the calculator, and with the other one, theres a mulltiple usb plug thing, kinda like a powerboard or whatever its called, where you can put in more then one usb cable. im not sure if that makes a difference, it hasnt affected anything before....
#9 casiokingdom
casiokingdom
  • 782 posts
Posted 12 February 2007 - 06:41 AM
Isn't that a hub then? Is this the computer that doesn't work?
#10 purplemonkey
purplemonkey
  • 13 posts
    casio fx-9860G AU
Posted 12 February 2007 - 08:13 AM
yes it is. my apologies, i should of looked closer at it. it has hub written on it. oops. :( i did look at it before but didnt see it...
and yes, that is the computer that doesnt want to work with me. so do you suggest waiting till i get the internet on my computer and then try? or is there some way around this problem?
#11 purplemonkey
purplemonkey
  • 13 posts
    casio fx-9860G AU
Posted 12 February 2007 - 08:44 AM
i took everything out of the hub and connected the calc straight to the computers usb port, and..... nada. :( it STILL wants to argue with me and says no more open file! no more open file no more open file no more open file no more open file no more open file..... its driving me crazy!
:profanity: :banghead: :( :angry: :wacko: :blink:
#12 k1cks
k1cks
  • 3 posts
Posted 12 February 2007 - 09:27 AM
Hey mate I fixed my problem, seems you had the same as me.
Go start - control panel - add hardware - next
It will then search for the hardware, and you click yes you have already installed it. and you pick the CSG502 or whatever it is and install that, it may take a few minutes and if you get a popup just clicky next!
That fixed mine, then you go into FA-124 and press the calculator and computer in the top right, and a bar comes up and connects it!
Have fun!
#13 purplemonkey
purplemonkey
  • 13 posts
    casio fx-9860G AU
Posted 12 February 2007 - 09:47 AM
ok thanks, im about to try that. ill let u no if it works in a min.
#14 purplemonkey
purplemonkey
  • 13 posts
    casio fx-9860G AU
Posted 12 February 2007 - 10:02 AM
okay,... the computer must really have something against me. i did what you said, but it still tells me it has no more open file. i went to start - control panel - add hardware - next, and then the closest thing seems to be 82852/82855 GM/GME Graphics controller. (thats the only thing that has any words in common with the calc (which is graphics), and i know what pretty mucheverything else is) It has two of them tho.... i picked that anyways, and it says the device is working fine.... :(
#15 purplemonkey
purplemonkey
  • 13 posts
    casio fx-9860G AU
Posted 12 February 2007 - 10:34 AM
WOO HOO LETS PARTAY! :rock: :rockband: I got it to work!!!!!! YAY! i shant tell my friends about this little mishap as they (my guy friends anyways) will probably make some refrence about the fact that i am a girl and they are guys and therefore would not have made that mistake, or about the fact that i am blonde.
So thanks for your help, ^_^ it really really helped, and without it i would probably be sitting on the floor by now, rocking back and forth whispering "no more open file no more open file no more open file"
lol.
#16 samy
samy
  • 46 posts
    graph 100; graph85
Posted 16 February 2007 - 06:23 PM
hello
I'm looking for a mean to find the address of the screen of the fx9860...
do someone knows how to do (or better do someone knows which ist this address)?
#17 Guest_scotty lad_*
Guest_scotty lad_*
  • Guests
Posted 02 June 2008 - 09:39 AM
well i got an error that says:
"no more open file"
any ideas i got the fa-124 off the net as ive lost my calcs cds need help with this for usage of assignments so if any idea please give us a shout
#18 Guest_Paul_*
Guest_Paul_*
  • Guests
Posted 09 September 2008 - 02:44 PM
I have the same problem and i tried everything you said, but it still doesn't work, any other tips? :banghead:
#19 Guest_raceyy_*
Guest_raceyy_*
  • Guests
Posted 13 November 2008 - 11:48 AM
install it,
it will keep on popping up with no file to open or whatever,
when windows pops up with found new hardware you must install it. and do it manually and then just go the what looks like the wrong road and sopmething that is out of your handskeep on selecting the bottom options. and then a pop up will appear saying that it could affect windows.
thats just microsoft being a dick, continue despite it and it will be installed
probs not the best explainnation but give installing it a shot and try all the options
#20 Guest_gina_*
Guest_gina_*
  • Guests
Posted 03 October 2009 - 09:31 AM
i could cry!
my stupid fx-9860 g has been connected to my computer dozens of times over the years... and next week is my big end of yr 12 exams and what do you know it deicides to do the no more open file thing
and iv tried going into hardwares etc.. but im on windows vista and havnt a clue where to go next.
ive checked my calc is on rguith settings .. USB, ON and Memory
and just nothing... please i need urgent help!
#21 Guest_Guest_*
Guest_Guest_*
  • Guests
Posted 09 October 2009 - 01:03 PM
yeh ive tried absolutely everything and it still doesn't work. Changing computer, cables, updating drivers.... nothing
#22 Guest_Guest_*
Guest_Guest_*
  • Guests
Posted 09 October 2009 - 01:13 PM
im the same user as above. I just got it to work :)
To everyone else, turn your calculator off and then on.
It worked on both computers straight away :D
#23 Guest_guest guy_*
Guest_guest guy_*
  • Guests
Posted 16 January 2011 - 03:19 PM
hey i have just tried connecting my calculator to the computer and its not working. It is an fx 9860G and i downloaded the fa 124 off of the internet. i have tried everything everyone has put on this page and it just doesn't seem to work. please help me
#24 Guest_Joshua Stephen_*
  • Guests
Posted 24 February 2011 - 01:19 PM
Cheers,
Jacob
#25 Guest_Joshua Stephen_*
  • Guests
Posted 24 February 2011 - 01:22 PM
I keep on getting Connection couldnot be established. either the connected calculator is not connected or the calculator is not in data standby recieve mode. PLEASE HELP ME!!!!!!!!!!!
#26 Guest_Joshua STephen_*
  • Guests
Posted 25 February 2011 - 07:31 AM
mine doesent get detcted!!! :(:(:(:(:(:( :profanity: :nonono:
#27 Guest_Guest_*
Guest_Guest_*
  • Guests
Posted 25 February 2011 - 11:22 PM
Goodday,
I am afraid that I can't give you a step by step guide from experience of connecting the specific model of calculator to a specific machine, but I can assist with an overview of the procedures common to most computers in interfacing tasks via usb, and the problems people sometime experience.
There are two principal methods of interfacing USB via software, one involves a terminal program, which manages the sending an receiving of the data to the USB serial chip via a driver interface. The driver interface is a small byte size extension to the operating system, it ostensibly contains a library of routines, which when called by using high level commands from the operating system, directs those commands through to very basic machine code assembly send and receives, all sycronisation speed and configuration parameters are describe exterior to the driver, all the drive does is channel information to a port, with low level machine code commands your serial chip understands.
So principal to interfacing is the requirement to have the correct driver for your usb serial chip set.
Upon boot procedure, the computer os searches out in a process call post. Post is a hardware evaluation task, that tells the operating system above it, what devices are present and what are not, drivers to load, and not as the case may be.
If the post test startup fails to recognise the casio, because your computer does not recognise the casio device as device supported by the operating system, the driver will load and fail the post check, if the casio is connected on reboot, effectively the driver activity is thereby suspended: this can sometime occur, and catch people off guard. The key is to ensure that the correct driver for your casio is installed, on your os and that the casio is not plugged in at the time of rebooting. Once the operating system has fully loaded, the presentation of the casio to the os, will call the driver to check the hardware and thereby recognise the device.
I said that their are TWO interface methods, driver and hardware are required for both.
One method to interface is direct connect, devices such as USB sticks etc, Sony and Phillips cameras and music players feature this, as do some telephones. Direct connect presents your peripheral as a hardware disk, all calls to that device are managed as though it were a disk through the operating system.
The second method to interface requires an application layer which manages the task of serially sending data to and from the driver through the operating system.
This is the program I gather you are experiencing problems with.
While it is necessary not to have external hardware devices present at boot, it may be necessary to have hardware devices present on the startup of the application layer program, ie plug your casio in before running the 124 program.
The advice given before by others is correct. The spring interface on usb peripherals tends to become unreliable with use. It is sometimes required to ensure that the contact springs on USB housing do in fact apply pressure to the the plug and therefore contact is sustained on the gold plated contactors. Failure in this field usually results in unreliable suspensions of os, hangs, failures to recognise peripherals and peripherals vanishing in mid flow, all this can result in the jock suggesting a reinstall of os, when in fact, the problem lies elsewhere.
Once your program is running, and your casio is interfaced, and present, and recognised by the application, file transfer is a matter of following the procedure in the manual for your device. A bespoke application layer taylored to your product usually does not require the user to configure additional parameter to interface a device, third party appliction solutions for hardware interfacing do require greater user experience and knowledge, for example something like the psion link requires the user to set baud start and stop bits, and the bits in the byte, and a protocol, which both devices understand, but this should not be necessary to consider if the application layer is supplied for your hardware peripheral by the manufacturer, they do their best to make things easy for you.
#28 Guest_cuebal_*
Guest_cuebal_*
  • Guests
Posted 08 June 2011 - 04:20 AM
does anyone know where i can find vector programs for the calculator casio fx9860g au?
#29 IrinaToplichanska
IrinaToplichanska
    fx-9750GII
Posted 01 September 2019 - 02:59 PM
The default button on my program fa-124 does not appear. Can you please help me ?
