Thank you for replying.
I have determined the answer;however, I agree I did not represent the problem correctly. No excuse other than having been in a Pre-Cal book for 10 hours. This week marks the first time I have ever turned on a graphing calculator. For clarification:
the problem reads, a rectangle is inscribed in a circle of radius 4. (therefore each vertex is on the circle) the center of the circle is at the origin (this was not defined, however the examples show this to be assumed in this section) Let P= (x,y) be the point in quadrant I which is a vertex of R. the funtion is x^2+y^2=16 the goal here was to construct a function of x by redefining y. y^2=16-x^2 then substitute the new value of y to determine a Area as a funtion of x, perimeter as a function of x, and then enter those functions into a graphing calculator to determine the Max A with the smallest positive x.
I knew how to work the problem, just not my calculator. I have been a paramedic for 12 years and calculators were always off limits. the micrograms per drop per minute per kg of patient weight had to be figured in our heads due to the possibility of having a patient and no calculator. I do thank you all, I have much to learn about this machine and will ask many stupid questions in the future.
Chau,
bg
