Problem With Text Reader !
Posted 26 February 2007 - 07:57 PM
So if you ever had this problem, please explain me how do you do to resolve it !!!
Posted 26 February 2007 - 09:57 PM
If that just confuses you, go to the matrix menu (accessed through the run menu) and look for any large matrices. I'd say if any matrix is above 10x10 or so, you might want to delete it. Most likely they're used for game or program data, so be careful about what you delete. Also look at the lists in the stat menu - I'd say lists of about 100 elements or more should be considered for deletion. Also check the other list files, if you know how to do that.
Posted 27 February 2007 - 02:00 AM
I have a problem, when i try to put the text reader reader on my fx-9860, fa-124 write "Memory Full Error", and i don't understand why, cause I delete many progs of my calc !!!
LOL! If you are getting this error on FA-124 (because I get the same errors over and over again also on FA-124), it's not my TXTREAD program that's causing the problem. When you import a add-in FA-124, (or any other program that is to be stored into the Storage Memory of the fx-9860) FA-124 creates 4MB "virtual" flash image in your Windows TEMP folder. The image just acts like the Flash memory on your calculator, except it's 4MB big. So you can only have 4MB of data stored under one Flash image for FA-124. When you delete something on FA-124, it's not really deleted, just like on your fx-9860. You have to OPTIMIZE FA-124 just like your fx-9860. This is not really known by much people because I think it's complicated for people to understand.
To make it simple, just delete everything under Default as shown in the image and right click on Default and click Optimization. Look to the image and look at the red circle:
After you have optimized the image, then import everything again. FA-124 should give you no more problems, unless you import more than 4MB of data into a single flash image....
Also remember to OPTIMIZE your fx-9860 (or Graph85 as it's called in Europe). It's may give you some space in your STORAGE MEMORY of the fx-9860. To do this, go to the MAIN MENU, go to MEMORY and press F5 (OPT) to OPTIMIZE.
Posted 27 February 2007 - 08:51 AM
Smal note: the fx-9860G is only in France (and maybe some other countries) Graph85. But there are Ameracans who don't believe in Europe .
Posted 27 February 2007 - 04:19 PM
I will try to delete flash memory today, i hope it will function, cause this programm is really usefull !!!
Posted 27 February 2007 - 06:12 PM
Posted 27 February 2007 - 06:44 PM
Posted 01 March 2007 - 02:35 AM
Anyways I updated the Text Reader. Now v1.50:
* 72% speed increase (time is proportional to how big the text file is)
* Pressing Shift' /> and Alpha' /> does a Page Up and Page Down respectively
* Pressing EXE' /> while viewing a text file now takes you back to the file manager. Useful feature, now you don't have to exit and go back in to view another file.
* Fixed text display error. Now it displays correctly 25 characters per line.
Would fx-9860 users of this forum like more useful utilities? I've been getting emails from a bunch of people saying that Text Reader is "brilliant" and "really great". What other useful utilities would you like to have on your fx-9860?
Posted 01 March 2007 - 08:53 AM
Posted 01 March 2007 - 02:48 PM
Great, its much faster now.
Thanks, but is Text Reader the only utility you want? What other utilities would you like to have?
Posted 01 March 2007 - 02:57 PM
@eew:"A tetris game would be nice"? You need it? Why? No tetris has already writen in Basic?
Posted 01 March 2007 - 03:21 PM
#14 Guest_dragnott_*
Posted 22 October 2008 - 08:49 PM
how do you inport txt files on the casio?
#15 Guest_Guest_*
Posted 13 June 2010 - 09:58 PM
Hey, did you find out how to do that?? (I see your post is from 2008, so maybe you solved the problem ). I need to know it too.
