That would be nice
Tutorials For 9860g Add-ins
Posted 03 March 2007 - 05:12 PM
That would be nice
Posted 03 March 2007 - 06:10 PM
then you can start learning casio c
After you learned C and are learning casio c use the source code of games to learn, use the PDF's from casio for the right syntax
On Casiokingdom there are some C-code snippets, pong from kucalc is quite simple to understand and has the source included.
Posted 04 March 2007 - 12:38 AM
Menno is right. Look for free C tutorials on the web. Once you mastered that, then read the manuals that go along with the fx-9860 SDK. That is probably the best way to learning how to use the SDK. Also my Pong game includes simple source code that you could learn from: http://www.casiocalc...?showtopic=3145
Posted 06 March 2007 - 05:16 PM
i now a bit like if, while, for,... is that enough?
Posted 06 March 2007 - 05:35 PM
then you know what you must know
as if we could know what you know based on one sentence
Posted 08 March 2007 - 06:40 PM
and I have much (boring) praxsis (i dont know whether this is right english
but it would be useful if someone write a tutorial (so i must not read the PDF's)
Horrowind
Posted 09 March 2007 - 04:28 PM
it is like :r-t-f-m:
just read it because the syntax of casio C is different then standard C
Guest_Khairy_*
Posted 09 March 2007 - 05:39 PM
Now i want to pick on this SDK. so I have to learn again
Your advice is this: Read up on C+ tutorials, then read Casio SDK C document, then try some program. Is that OK? Anything else I can do to learn faster?
Do I read up C or C++ tutorials? I read some tutorials and I found that there are many differences in C
I am ok with Casio Basic but in writing big program Basic is worthless, so SDK is more useful.
Some idea on how to procedd better would be nice, thanks.
Posted 09 March 2007 - 09:17 PM
why isnt there anything on the display?
#include "fxlib.h"
unsigned int x,y;
x=3;
y=3;
while(GetKey("KEY_CTRL_EXE")){
if(IsKeyDown(KEY_CTRL_UP)&&x!=1) {x=x-1;}
locate(x,y);
Print((unsigned char*)"T"); <-??????
return 1;
}I want to build a game where i can move a "T".
Posted 09 March 2007 - 09:26 PM
Is it possible to open an Add-In from a Add-In/from the SD-Card?
Posted 10 March 2007 - 01:29 AM
I have a problem:
Try my code:
unsigned int x,y,key;
x=3;
y=3;
while(key != KEY_CTRL_EXE) {
Bdisp_AllClr_VRAM();
if(IsKeyDown(KEY_CTRL_UP)==1)
y = y - 1;
if(IsKeyDown(KEY_CTRL_DOWN)==1)
y = y + 1;
if(IsKeyDown(KEY_CTRL_RIGHT)==1)
x = x + 1;
if(IsKeyDown(KEY_CTRL_LEFT)==1)
x = x - 1;
if(y <= 1)
y = 1;
if(y >= 8)
y = 8;
if(x <= 1)
x = 1;
if(x >= 21)
x = 21;
locate(x,y);
GetKey(&key);
return 1;
}Press
Another Question:
No, but you can write a add-in that reads data from the SD card.
If you need more help just ask me.
Posted 12 March 2007 - 07:05 PM
There are tutorials for Casio Basic, but there are no tutorials for Casio C.
There are users, who don't want to read the PDFs (like me
so i tell you the request:
so i understand more
Posted 29 August 2011 - 06:07 PM
