Wrong Solution Of Some Differential Equations
#1 acid111
acid111
  • 31 posts
    Classpad OS 3.01
Posted 22 April 2007 - 07:29 PM
Hi, i'm german and i hope you can understand all what i'm going to write :D
ok, i tried to check a solution, that i calculated by hand, with the classpad
but the classpad showed me an other solution as i calculated.
But i know that my solution is the right one :D
here is the differential equation:
y'' + 2y' - 8y = 3e^(2x)
the right solution is: y= C1*e^(2x) + C2*e^(-4x) + 0,5x * e^(2x)
but the classpad shows: y= C1*e^(2x) + C2*e^(-4x) + 0,5x * e^(2x) - 1/12 * e^(2x)
why does the classpad calculate a wrong solution ?
Can you try to calculate this equation with your classpad, maybe its only my classpad :)
shall i better send this problem to casio ?
thx
#2 PAP
PAP
  • 681 posts
Posted 23 April 2007 - 11:01 AM
here is the differential equation: y'' + 2y' - 8y = 3e^(2x)
Hello, and welcome to this forum ;)
The solution you get is not wrong; in fact, it is equivalent to your "by hand" solution:
C1*e^(2x) + C2*e^(-4x) + 0,5x*e^(2x) - 1/12*e^(2x) = (C1-1/12)*e^(2x)+C2*e^(-4x)+0.5xe^(2x)
Now, since C1 is an arbitrary constant, C1-1/12 is also arbitrary, so these two solutions are equivalent. ClassPad returns a slightly different solution probably due to the way it uses to solve the differential equation. I admit that the solution obtained "by hand" is more compact, but ClassPad's solution is correct as well. Btw, Mathematica's solution is identical to ClassPad's solution.
#3 acid111
acid111
  • 31 posts
    Classpad OS 3.01
Posted 23 April 2007 - 03:05 PM
yes, you are right !
i haven's seen it, hmm ... :banghead:
ok, now i think that i can trust the solutions of the classpad... :greengrin: :roflol:
thank you !
#4 The_AFX_Master
The_AFX_Master
  • 519 posts
Posted 23 April 2007 - 05:14 PM
I managed to solve the equation via Laplace transform on the OS 3, and i got the same result. then i guess that the calc uses laplace transforms to solve linear ODE's
#5 PAP
PAP
  • 681 posts
Posted 24 April 2007 - 06:49 AM
Hmmm, not necessarily. The differential equation is linear to the dependent variable y, so it may use other methods to solve it analytically. Anyway, Laplace transforms can be used as well.
#6 Guest_Logicman112_*
Guest_Logicman112_*
  • Guests
Posted 23 February 2011 - 06:05 AM
If we have a linear system with the following differential equation:
d2y/dt2+7*dy/dt+12*y=dx/dt+5*x
So H(s) = (s+5)/((s+4)*(s+3)) = -1/(s+4)+2/(s+3)--> h(t) = (-e^(-4*t)+2*e^(-3*t))*u(t)
(Please calculate the unit impulse response by Laplace transform and verify the result by yourself)
Why this answer does not satisfy the differential equation?
The right answer is:
h(t) = (-2*e^(-4*t)+3*e^(-3*t))*u(t)
