Help With Fx-570es Please
#1 r.youden
r.youden
Posted 10 May 2007 - 03:53 PM
Hi everyone, new on here so if what i am asking has already been covered please direct me to the right place.
Right, I just got a new FX-570 and I am struggling with the Matrix side of the calculator. As with most Casio products the instruction manual is a nightmare so I have come here for some help.
What I want to do is multiply two matrices, not too difficult eh!
Well, I enter the values from Matrix A, then enter the values for matrix B, try and multiply them together and get a dimension error. Then I look for the values in matrix B and they are still there, but when I look for the values in Matrix A they are not there.
I am guessing that you may need to load the values for each matrix into memory but I a not sure on that. Any advice would be great.
Thanks.
#2 N467RX
N467RX
  • 15 posts
    Casio CFX-9950GB PLUS
    Casio fx-7400G PLUS
    Casio fx-991ES
    Casio fx-85ES
    Casio fx-115MS
Posted 11 May 2007 - 01:03 AM
Do:
Shift+4[Matrix]
1[Dim]
1[Mat A]
Shift+4[Matrix]
1[Dim]
2[Mat B]
Shift+4[Matrix]
2[Data]
1[Mat A]
Shift+4[Matrix]
2[Data]
2[Mat B]
AC
Shift+4[Matrix]
3[MatA]
X
Shift+4[Matrix]
4[MatB]
Should work, give it a try (at least worked with my 991ES)
#3 Guest_awesome_*
Guest_awesome_*
  • Guests
Posted 25 July 2011 - 01:29 AM
you really helpd i had the same problem, thank you so much
